Dual Voice Coil vs Single Voice Coil
13 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Quick sub Guide
In my opinion
Dance/Club/HipHop = 2 x 12" Subs
Jazz/Blues/Trance/Hrdcore Music = 12" Sub
Alternative/Rock/Pop/Classic = 10" Sub(s)
15" is just too big for sound quality, it drowns out the treble from the speakers
id recommend all to be DVC (Dual Voice Coil), they cost roughly 1.5x a SVC (Single Coil), it reproduces better bass and gives more kick
also it allows you to change the way your subs work.
If you need to know what the ohm value is
the ohm value is a resistance value, in the case of a speaker or sub, it determines how much vibration (the kick) vs how much bass (the clarity of the deep boom sound)
1 ohm setup would have max kick but least amount of boom
2 ohm setup would have a big kick but slightly more boom
4 ohm setup is the default which most SVC subs are made, this has the somewhat near perfect kick vs boom
8 ohm setup is the clearest out of all of them, this has the least amount of kick but very clear and defined bass
all these assumptions are made when the box is at the sub's recommended volume, by varying the volume of the box you can create tighter bass (more kick less boom) or deeper bass (more boom less kick)
SVC has single + and - input which only allows a single Ohm value, eg. a 4 ohm sub 1000W 500RMS would stay only at 500RMS and the level of bass stays the same
DVC lets you have more fun because it has 2 + and 2 - inputs which lets you decide on which ohm to use, on the box of DVC sub it would say 1ohm compatible or 2ohm compatible
that just means the minimum ohms. this is achieved by using a small cable to run it in parallel or series. DVC would always sound way better than SVC
visit here for the setup guide
http://www.kicker.com/dvc_wiring
Amps must also be for subs, do not use power amps for subs as they contain 2 or more mono blocks which shares power and when you plug it into one terminal, the sub quality becomes dependant on how much power the amp is willing to provide for each block. the other problems with is its frequency band, there will be a lot of distortions as they were made for applications for 100hz to 44000hz at 8 ohms* and the subs only run between 15 to 200hz*.
For subs always use a monoblock (amp class D) as they are more refined in quality contains only a single block, provides constant power supply and outputs between 10hz to 200hz*. These do cost slightly more but this was made specially for subs.
*Average Entry Level products
The headunit must also cutoff the low frequency from the speakers so if your mono amp is set at 80hz, you should set the speaker cutoff at 80hz as well.
Cables 4/8 gauge^ is good for 12v and ground. 8/10 gauge^ is recommended for sub cables and 10/12 gauge^ is for speakers
Cable quality does matter in some respects, the quality is in the mixture of the cable whether it is gold, copper or silver they provide near same level of quailty. the insulator though that come with this cable is very important. You can tell whether the insulation is good or not by how much they bend, usually a better one is harder to bend than the cheaper brands. i'd just go for stinger or a better brand.
^the smaller the gauge number the bigger the diameter of the cable
My setup 1800W Kenwood Mono Amp, 12" 1000W 500RMS DVC CompVr Kicker Sub at 4ohm, 12" 1500W 500RMS DVC Kenwood at 8ohm.
210W Alpine type S Splits, 250W Kicker Speakers. 1.5F Capacitor, 7" Pioneer AVH6850DVD in-dash 6 DVD stacker.
R33 GTST
anything that i need to add or change?
https://www.sau.com.au/forums/topic/287483-quick-sub-guide-dvc-vs-svc/
after reading the first two paragraphs of your post i have come to the conclusion that you have about as much knowlage on this subject as a box of cheerios. For the love of god dont come on a fourm and start posting rubbish like that.
Theres being missinformed and then theres what you posted up there.
My resonses are in Bold.
Quick sub Guide
In my opinion
Dance/Club/HipHop = 2 x 12" Subs Completly depends on model of sub. There is no "magic" number of subs.
Jazz/Blues/Trance/Hrdcore Music = 12" Sub As above
Alternative/Rock/Pop/Classic = 10" Sub(s) As above
15" is just too big for sound quality, it drowns out the treble from the speakers Rubbish,Completly depends on enclosure design. If a 15's sub is going to drown out your treble ANY sub will.
id recommend all to be DVC (Dual Voice Coil), they cost roughly 1.5x a SVC (Single Coil), it reproduces better bass and gives more kick being DVC has NO effect on sound quality. Its only used to give more wiring options for better use in multi sub systems or better wiring options with different amps.
also it allows you to change the way your subs work. How is it going to change the way they work? there going to be getting fed an AC signal no matter what you do.
the ohm value is a resistance value, in the case of a speaker or sub, it determines how much vibration (the kick) vs how much bass (the clarity of the deep boom sound) Rubbish. It is however a measurment of resistance.
1 ohm setup would have max kick but least amount of boom wrong
2 ohm setup would have a big kick but slightly more boom wrong
4 ohm setup is the default which most SVC subs are made, this has the somewhat near perfect kick vs boom wrong
8 ohm setup is the clearest out of all of them, this has the least amount of kick but very clear and defined bass also wrong.
Using a low ohm wiring configuration will reduce the sound quality abit. How ever the difference is arguable at best, you would never be able to tell the difference in a back to back test,Using a lower ohm load on an amp will generally let the amp make abit more power though, within its limits of course.
SVC has single + and - input which only allows a single Ohm value, eg. a 4 ohm sub 1000W 500RMS would stay only at 500RMS and the level of bass stays the same I dont know what your trying to get at here but an amplifier wont just supply 500wrms of power to a sub,there not like light switches. Any speaker/Sub power rating is a THERMAL RATING ONLY. Meaning its VC can take upto the listed amount before it burns. It is possible to exceed its thermal limits for short periods of time though. You will generally reach the subs mechanical limits long before you come close to its thermal rating under most circumstances.
that just means the minimum ohms. this is achieved by using a small cable to run it in parallel or series. DVC would always sound way better than SVC Wrong, i have already explained why above.
Amps must also be for subs, do not use power amps for subs as they contain 2 or more mono blocks which shares power and when you plug it into one terminal, the sub quality becomes dependant on how much power the amp is willing to provide for each block. the other problems with is its frequency band, there will be a lot of distortions as they were made for applications for 100hz to 44000hz at 8 ohms* and the subs only run between 15 to 200hz*. Not always the case. For most people using a bridged multi channel amp is more then sufficiant for the average joe.Your argument about problems with the frequency brand is rubbish. What amp are you thinking of that will do upto 44 000hz? they will generally be rated to +/- 3db upto 20 000hz.
Cables 4/8 gauge^ is good for 12v and ground. 8/10 gauge^ is recommended for sub cables and 10/12 gauge^ is for speakers The gauge of power cable to be used is dependant of the current draw of the amp(s) you are using.8 gauge is massive over kill for a sub system.Like wise with your recomendation for speakers. It wont hurt tho if you feel the need to use it its your money. Why do you keep putting ^ at the end of gauge? it has no relevance to it what so ever.
Cable quality does matter in some respects, the quality is in the mixture of the cable whether it is gold, copper or silver they provide near same level of quailty. the insulator though that come with this cable is very important. You can tell whether the insulation is good or not by how much they bend, usually a better one is harder to bend than the cheaper brands. i'd just go for stinger or a better brand. The better quality stuff is actually easier to bend which makes it easier to work with.
^the smaller the gauge number the bigger the diameter of the cable Correct.
R33 GTST
Why are you running two completly different model subs. Please tell me your not running them from the same amp.....
Id suggest you do alot of reading on this subject before you try to give advice to other people, For there own good.
Edited by Jack88
Jack is very right
This guy has NO CLUE HOW SOUND WORKS , DO NOT LISTEN TO HIM
thanks for that for clarifying, i probably should've worded the topic post properly. all the info at the top of this page is what i got told by various people and just wanted to know how much of it is correct. i did put "In My opinion" at the top and what i meant with "quick sub guide" was that I need help quickly to fix my system. its all in pieces atm
SORRY for the Confusion, bad english. :P:P
Edited by GHO5T_R3AP3R
Thanks Jack i was planning my responce then realised that you pointed out basically everything i wanted to say!!! I also couldn't be bothered reading the post :P
One more thing I wish to add is apart from aesthetics or SPL comps i can't think of any reason for having more then one sub. I have a single G5 and when it's turned up close to full i can only stand it for under a minute before it starts to actually hurt my ears. One good sub will out perform 2 cheaper subs any day.
Thanks Jack i was planning my responce then realised that you pointed out basically everything i wanted to say!!! I also couldn't be bothered reading the post :)
ok what every you say.. the enclosure can make or break you... I can put a 100.00 dollar sub in a perfectly spec'd and pro built enclosure and you would swear it was a 1500.00 one
or I can just dump a 1500 speaker in a 50 dollar generic box and it will produce generic sounds
I think most of the old master installers here would agree ?????
you can have a +20 from me lol, knowlage like this is why they call us master installers.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
