  • Replies 203
As per april apparently you cant even have well secured pod without permit
youve got 2 option
1. kyp had it approx one month ago when I call for the same exact reason should cost 80-100
2. apply for a minor mod permit, cost u 25-30 but the catch is gotta wait 2-3 weeks but hey from then on your pod filter is legal
hope that helps
Hey guys I am after a set of stock v35 rims to register my car here from Victoria. Won't be after them for another week or two. Will be willing to shout someone a carton of beer if they want it.
  • 3 weeks later...
  • 1 month later...
Its been a while and I still have no luck in finding a stock exhaust not even by buying..
Can someone help me or point me out to who might have it?
Also I will always have
Stock RB25 BOV
Stock R34 GTT suspension (lowered springs though ie. too low for stock rims)
cheers
bly
I really need a standard rb25 BOV if you could help me for pits
My number is 0413775441
Cheers
  • 3 weeks later...
Hi all,
Just got my first yellow for dark tint on my R34 GTT and want the car to pass the pits first time.
I was wondering if anyone was able to lend me the following for a few days:
  • Stock R34 suspension (shocks/springs)
  • Stock R34 wheels with tread if possible
  • Stock R34 BOV
  • Stock R34 airbox
I would gladly shout anyone a carton of booze of 2 of their choice and/or cash for any help on these.
Thanks heaps!
Brett
Hey guys,
This is pretty urgent. My car is booked in for a tune on the 24th of Sept, but I have lost the valve seat from my Turbosmart Compgate 40 and no dealers in Perth will have any in stock for 2-3 weeks. Obviously without this I won't be making any boost, so the tune is pointless and I will miss out on Powercruise. If anyone has one I could borrow so I can get my car tuned, I will be your best friend!!
Either PM me or send a text on 0431047984. Cheers guys!
Martin.
I'm running out of time to get parts so I am thinking of taking the car over the pits with removed tinting but leaving on BC adjustable coilovers (raised height), GTR rims and mismatched tyres 235 front and 265 rear. Added stock BOV and airbox and will be making sure car is clean and tidy.
Crossing fingers I get someone good at Welshpool pits - tinting is the only think to be checked but I'm sure if I get an asshole they will check everything. Anyone else passed with similar mods?
Edited by Everlong-S13
Not for the pits but does anyone have a standard turbo neo ECU (auto or manual) I can borrow to diagnose what I think is a dead ecu? Any help will be rewarded with beer for the drive home :cheers: .
0416 914 448
Hey guys, looking for someone to help me re: xenon headlights for compliance.
Either someone willing to swap legal R34 headlights for a couple of weeks, or help me temporarily change Xenon HID'd to legal H1's without mutilating anything so I can simply go back to Xenon after.
Willing to pay cash or booze for any assistance.
So they did the D2R to H1 conversion on your low beams? I have a feeling they converted mine to H3, but I will have to check. Either way I have stock high beam globes, and depending on your lows, I may be able to help with them as well. If not I can source some cheap globes - as in, I will 'borrow' them from work. That was the only thing they defected you for? Xenons? Hahahah, that sucks! I have been running 35w HID's on my lows for a year, and 55w HID's on my highs for 6 months. The ballasts aren't even secured under the bonnet, I kind of just wedged them in there.
I am getting a yellow soon, I can just feel it.
Edited by voncina
Hey mate,
Nope not only thing I was defected for, a lot of other stuff.
I don't think my headlights were changed at compliance, so I'm chasing some sort of way to get over the pits and go back to the Xenon HID's after.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
