hi all, im currently rebuilding my spare engine at my garage.
ATM, looking for a good & cheap :) shop in canberra to:
- shot peened my gtr rods & freshen up the rod stud bores.
- decked bottom end surface (before putting head gasket)
- freshen up the bore before putting new studs.
- balanced my crankshaft
and how much $$ im going to spend each?
i'm not looking for a cryogenic cranks etc, just to do basic rebuild stuff.
and lastly, does anyone have any prev exp for tuning pfc in canberra? i know lots of famous one in sydney but i wont be able to drive it to sydney.
thanks.
https://www.sau.com.au/forums/topic/287706-what-shops-to-go-rebuilding-my-neo/
Oh he wants the work done.....I thought he had it done and wanted a rebuild. Present and past tense ing vs ed, so yeah pro engines for any machining etc
Plus it still stands for pfc anyway.
No PM's from me, It's a waste of breath and as correctly pointed out each persons experience is different.
Slaughter - Ditto mate, I have experienced the same pain on a rebuild. Take solace in my sig.
I've been burnt by Autotech. >.< Shame because Ed and the others there are great guys.
Plus, I don't think they are cheap.
For mechanical I'll be taking mine to TopSpec in Hume.
I haven't had anything 'big' done with him, but he's been great for the things I have had done there and all for a good price.
Also, girlfriends dad takes all his business cars there and recommends him.
Meh, every shop has bad feedback. I wont name them but I have had work done at a particular shop and was totally shocked at the price tag but they did do good work. Some times you luck out some times you don't
just got quote from proengines.
Just sharing for reference on machining cost for RB25det:
shot peen conrod $120
close & grind conrod $132
mill 6 cyl block - trade $100
machine hone 6 cyl $100
machine + fit crank collar $300
balance 6 cyl $225
check size & polish 6 cyl crank - trade $80
chemical clean 6 cyl $135
can upload the pdf if u want.
some questions:
what is mill 6 cyl block - trade? is it shut & grind new main stud hole?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
