folks,
just a quick thumbs up for the aforementioned tyre. i've had them on the vehicle for about 5,000km's with 2 trackdays and they are holding up extremely well, i predict them getting to 15,000km's without any drama's. I have 17inch all round, 255/40 on the rear, 235/45 on the front. Suspension setup helps alot though, i have Whiteline swaybars, camber & castor kits aswell as a rear diff brace.
In the Wet:
fantastic - you can easily light up the rear's but i put that down to a function of high powered rear wheel drive rather than lack of grip. Put it into a corner and it turns without understeer, maybe a touch of oversteer. With traction control on, its like driving a AWD - it has that much grip. In heavy rain i have never experienced aqua planing, water just washes off them...
In the dry:
sublime - grip when you need it without squeel or road noise! i am absolutely dumbfounded by the amount of road noise these tyres produce - practically none! for its soft compound nature, the road noise of these tyres are amazing! tyre wear is also impressing me especially after 2 trackdays and 5,000km's.
On the track:
utopia - im sure an Rspec tyre will have alot more grip but for the money i paid you just can't go wrong. just after the suspension was installed i had the tyres put on aswell. on the first trip down the car was terrible, i was understeering all over the place. dropped the tyre pressures on the front and it pulled it back in a little but it still had excessive understeer. on my return trip i tweaked the rear sway bar to its hardest settings and played with tyre pressures till i had the car almost the way i want it. it still has some understeer but the its more nuetral than anything. thumbs up.
they come highly recommended and i will definately be getting them again pending its tyre wear...as i said i've only ran them for 5,000km's i'll have to report back how much i actually get out of them - perhaps in a year or so then i guess :cheers:
price?
~$1300 fitted & balanced for all 4.
Yep - concur fully!
I had Trampios on my car when I bought it - everything you say.
I didn't replace them because they wore too quickly on the inside and outside, but this turned out to be worn bushes on the upper control arms. I went for Firestones instead and while I don't have any complaints about them either, I seem to remember that the Toyo's gave noticably better grip and especially feedback.
so how much each? about $250 ?
thats hella cheap for 2x 255s and 2x 235s fitted!
need new tyres in the next week, wheres somewhere to get them in brisbane?
Hornibrook Motorsport sells them. He was handing out flyers last time out at Queensland Raceway. His business is pretty new so he would probably do you a good deal. I am going to give him a call when I next need tyres, he speciality is R-spec tyres so he seems to know his stuff. He is a mad keen motorkana man too so he speaks from experience. Unit 1, 5 Basalt St Geebung. 07 38651072. Let us know how you get along, like I said haven't bought anything off him yet, haven't needed to, but he seemed good.
buzz, great to see someone else using them, you mentioned that you bought the car with them on, do you have a rough estimate as to how many km's you put on them before they had to be replaced and how much tread, % wise, was on them when you bought the car?
rob, no probs. hope they impress you as much as they've impressed me!
knore, unsure of availability in brisbane, i would say goto your local and see if they can order them in at worst case? price was $300 for fronts, $350 for rears - they'll usually help you out on installation costs if you buy the whole set ...
  • 7 months later...
Any ideas why Toyo's australiab web site says they are only avaliable in a 215/45 17" or a 205/50 16" ? Are you sure you got a 255 in a R1R and not the RA1? I rang a toyo dealer and they say only RA1's are in 255/40 17"
Comments?
Ok I rang stuckey tyres and they say they have a 255/40 17" in R1R's. The Toyo web site must be old. The price was $519 each! where did you get yours from? Cause if I could get $350 for 255/40 17" I would buy them now.
Yeah tell me about it... I've been trying to get something going for about two months thou.
Firstly the budget simply doesn't stretch to $520 a tyre. Everywhere I rang for the Toyo's said 500 - 520. The Bridgestone RE55 are not going to be in for at least another fortnight. (Have been calling the guy for months to keep checkin') The Falken's are in shortage due to a fire in Japan or some shit like that. No one's got any of them!!
You got any other suggestions for me?
Here is my research so far. Based on a 255/40 17", per tyre.
Falken Azenis ST115 - $320 - No stock
Falken Azenis RT215 - $340 - No stock
Toyo Trampios R1R - $519 - Avaliable
Toyo Proxies RA1 - $460 - Avaliable
Yokohama A048 - $520 - Avaliable
Yokohama A032 - $548 - Avaliable
Bridgestone RE55 - $400 - In a container at customs
Dunlop DJ01 - $521 - Avaliable
Scotsman, there is a place here in Adelaide that does RE55S 235/45/17 for around 350 each fitted, Not sure about 255/40/17. If I go to R rubber on the rear again, I will be going 235 in the RE55S, as they seem to be damn near the same width as the 255/40/17. They are wider than the RE540 in the same size anyways.
if you like I can get his number and he can send some over. They told me they send them over pretty regularly.
Yep, that's Kym at Magill.
The inside of the tyres arent holding up so well with only 2 deg camber - but the rest is good - excellent grip and great handling. Heaps of tread on the outside, so it looks ok:p
Havent measured them exactly - but they sit wide on the 8" rim up front, wider than the rim slightly - lucky it has such a stiff sidewall. I might take to em with a tape measure tonight:)
One day late but here nonetheless:
Trampios R1R 255/40 x 17 = $350 a corner.
235's and 245's are low in stock.
limited supplies till further notice, so place your orders.
email me.
i can also get Dunlop R Specs, just confirming on price and tread pattern.
shipping to melbourne can be organised.
Franks,
Thanks for you efforts. But since I need them on the car today or tomorrow I will have to go with something local.
I will keep these in mind for next time thou, as I would have gone for this if I had more time.
Is this a special price for you, or can I contact this dealer myself when the time comes for more rubber? Who is this through? "Kym at Magill" I assume?
Thanks again.
So these grip really well in dry?
Im after a soft compound tyre that really GRIPS in the dry
I was leaning towards Falken RT215s, i know u havent used these, but how do u think they'd compare?
They are both about same price, from looking at the grip, the toyos are semi-slicks yes?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
