p.s I dont like getting into the kick pannel were the ecu is as I belive the more one root's arround with it the more likely some of those fine wires will break in the socket.
The less you remove the ecu the better.
Note it would be quite costly to replace the scoket that plugs to the ecu. It could also cause faults that are hard to trace.
Thats why I think its better to reset the ecu the paper clip way.
my 2 cents
DAMQIK
just tried the paper clip method. it worked!! realised i was putting it in the wrong holes wen DAMQIK said that the points had wires going into them. i was putting the clip into 2 empty ones hehe.
the engine check lite flashed 5 times slow, and then 5 times quick? and then just kept repeating itself after that. anyone know what that means?
  • 2 years later...
I know this is digging up an old thread, but I thought the paper clip trick only reset the diagnostics (this needs to be done after replacing a faulty componant) mode not the actual ECU (learning). Droppng power to it and draining off any power by pressing the brake or leaving over night is the only way I know..
  • 3 months later...
  • 3 weeks later...
Hey guys, the diagnostic tool you need isnt expensive! and you can share it with any mates that have a pre 97 Nissan with the grey consult diagnostic port. If you have a laptop ,USB ECU Interface cable and software can cost as little as $155.
If you are interested, check out my ad in the 'for sale from our sponsors' .
Im quite happy for you to borrow mine too if you are Sydney based.
Cheers,
Caz... :D
I really don't think it would have done too much.....the proper diagnostic tool is needed and after the reset there are certain driving processes it needs to help the computer 'learn'.
CODE 13 is Engine coolant temp sensor, very common fault. Remove and clean the connector with a tiny file and contact cleaner, retension the insides so they connect well, clear the fault from your ecu , replug and try again!
ECU SELF-DIAGNOSTIC ERRORCODES
Code 11* :
Camshaft Angle Sensor circuit (CAS)
Either 1° or 120° signal is not entered for the first few seconds of engine cranking,
Either 1° or 120° signal is not input often enough while the engine speed is higher then the specified RPM.
Check harness and connector (if harness and connector are OK, replace CAS)
Code 12 :
Air Flow Meter circuit (AFM)
The AFM sensor circuit is open or shorted (abnormally high or low voltage is registered).
Check harness and connector (if harness and connector are OK, replace AFM)
Code 13 :
Engine Coolant Temp. Sensor
The Engine Coolant Temp. Sensor circuit is open or shorted (abnormal voltage is registered).
Check harness and connector of Engine Coolant Temperature sensor
Code 14 :
Speed Sensor circuit
The Speed Sensor circuit is open or shorted.
Check harness and connector speed sensor switch (reed switch)
Code 21*
Ignition signal circuit
The ignition signal in the primary circuit is not entered during engine cranking or running.
Check harness and connector of the Power Transistor Unit
Code 26
Boost Pressure sensor (Turbo models)
The boost pressure sensor is open or shorted (abnormally high or low voltage is registered).
Check harness and connector, check for boost pressure leaks, check boost pressure sensor
Code 31
Control Unit
ECU calculation function is failing Replace ECU
Code 32
EGR function
EGR valve does not operate (valve spring does not lift)
Check EGR valve and EGR-solenoid
Code 33
O2 Sensor (left side)
The O2 Sensor is open or shorted (abnormally high or low voltage is registered).
Check harness and connector, O2 sensor, Fuel pressure, Injectors, Intake air leaks
Code 34
Detonation Sensor circuit
The detonation sensor circuit is open or shorted (abnormally high or low voltage is registered).
Check Harness and connector, detonation sensor
Code 35
EGR Temp. Sensor
The EGR Temp. Sensor circuit is open or shorted (abnormally high or low voltage is registered).
Check harness and connector, check EGR temp. sensor
Code 42
Fuel Temp Sensor circuit
The Fuel Temp. Sensor circuit is open or shorted (abnormally high or low voltage is registered).
Check harness and connector, check Fuel temp. sensor
Code 43
Throttle Position Sensor circuit
The Throttle Position Sensor circuit is open or shorted (abnormally high or low voltage is registered).
Check harness and connector, check throttle position sensor
Code 45
Injector leak
Fuel leaks from the injectors Injectors
Code 51
Injector circuit
The injector circuit is open
Check harness and connector, check injectors
Code 53
O2 Sensor (right side)
Check harness and connector, O2 sensor, fuel pressure, injectors, intake air leaks
Code 54
Signal circuit from the automatic transmission (A/T) (A/T models only)
The A/T communication line is open or shorted
Hope this helps,
Cheers, Caz... :D
can someone please post what all the codes are? i cant find it, and me mates has just started flashing code 13.
  • 7 months later...
absurdely old topic and all but, the above list of problems do you need the ecu diagnostic tester to assess? or is there like a LCD screen in the ecu that gives u codes or a LED
thx itd save me asking alot of questions if i could get these codes goin. That and i dont like pulling kick panels apart and going near old wiring if i dont have to
Edited by r32 gts-turbo
  • 1 year later...
  • 2 months later...
i know this may seems as a bit of a noob qs but is there any harzards involved with resetting the ecu???
i recently had a faulty afm which i fixed by resoldering the three pins inside on the circuit board, i was getting stalling and hesistation problems all the time and the car chewwed fuel like no tommorow, but the car still seems to run a little rough around the 3 - 3500 rpm mark hesistating and there is a significant power drop, i was wondering whether resetting the ecu wud help it to re learn the correct air/fuel ratios now that the afm is fixed if this has anything to do with the problem???
please feel free to correct me if i am wrong as im new to this game
Cheers Nick :O
Resetting the ECU lets the computer retune to suit the fuel mixtures your running (depends on fuel & quality/location etc.). Your ECU will do this/reset itself automatically after 50 starts or so anyway...
Occasional backfire could be from a number of things, TPS, atmo BOVS, coolers etc. but firstly look at the timing/tune. Crap fuel shouldnt cause a backfire just a more spontaneous combustion rather than top/down??
The only benefit you'll get from resetting the ecu (apart from resetting other computers) is that the fuel mixtures are more aggressively tuned (i.e. first tune to suit first run), and that benefit will only be realised if you keep using the same blend of fuel i.e. BP Ultimate, Shell Optimax etc. all the time. Ive been told that this occurs dynamically (real time) aswell but it is far less aggressive i.e. tune happens over weeks rather than minutes
Just keep using the same fuel and your ecu will reset itself automatically at some stage. Not sure about the diagram above but the R32 and 33 pinouts are different. Just unplug battery +ve and hit the brake pedal to remove residual - this will also work with most other cars.
An automatic shop tried to charge me 150$ to reset the Auto ECU in a magna doing the same thing, Nissan charge $70 for an ECU reset also, 120$ for a reset & a consult - ridiculous!!
  • 2 years later...
Hey
sorry to start this topic again. I'm about to do a 100,000km service and I would like to reset mystock ecu but I'm not sure what to do as I have a rb20det? Disconecting the battery really work? Can sum1 please explain how reset the ecu on r32?
Cheers
thanks for bumping a 3+ year old thread
to do stock ecu reset undo the battery terminal and press the brake pedal a few times
it will clear out all the power in the system and reset the stock ecu
it will also reset the headunit and other non-nvram based electronics
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
