  • Replies 140
I like custom plates, they give the vehicle an identity.
I'd go with either FORCED or NOXCUSE, as both are cool. Just remember that custom plates do attrack some attention depending on what they say. I get a few looks with having DRFT-32 on my car.
I always thought IXL 005 would be a cool plate aside from the fact you'd get pulled over (even more) than usual
-D
I like my plates tbh, makes it easier for people to spot :D
Personal choice really... I ummed and aahed about it until i said 'screwit' and just made the purchase... infact I think I remember telling someone how much of a wank they were before getting them. I have trouble making up my mind sometimes...
-D
haha, yeah i like the look of custom plates and its alot easier to spot cars time after time.. chose my username after i made sure the plates would be free seeing as RIPPER was already taken i settled with RIPP3R..
Use NOXCUSE buddy
So you have been paying $250 a year to maintain those plates? Otherwise I am pretty sure they lapse and someone can simply buy them. You may physically have the plates, but are you sure you still own the right to display them?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
