Just finished Brembo conversion on my car
documented some details and so on.
and took alot of pics
Brembos Finally arrived
Closer look at the front.
With the Rest of my stuff
Slotted EBC rotors and EBC red stuff brake pads
Standard Front
Standard rotor vs new 324mm rotors
Fronts installed
The fronts where pretty easy and straight forwards but you must use the brake lines off the 350gt as it will be a straight fit
using the brackets
The rears needed abit of modification on the dust cover and the brake lines needed some custom mountings
dust covers designed for the standard rotors
Had to get a nibbler and modify it
Rear brembos installed
*the standard caliper blots coudlnt be used cuz it had a finer thread u can either use OEM Z33 or aftermarket caliper bolts
https://www.sau.com.au/forums/topic/288150-m35-brembo-brake-coversion/
So stolked to see that Danny! Its exactly what I have been planning.
Can you give me the part numbers for the rotors you used. Also did you need to to make a mounting adaptor for the rear calipers, or just make room with the dust tins?
Ben.
i can provide you all the part numbers
but only mod to the rear was the dust pan and different bolts
no mods were requiered to fit the rear
price wise would set u back 2.5K-3K
obviously i didnt pay that much for it lol
going to finish off blddeding the brakes today
so ill let u guys know how it feels
is there a chance youll have to upgrade your master cylinder?? else youll be pushing VERY far on the pedal before it grabs. might need to get the master from a brembo equipped V35 (if they are different)
too much movement..
it's not hard enuff for brembos
A larger piston master cylinder will help but if your pedal isnt too low, see how it goes.
Have you bed the brakes in properly? Go for a thrash through the mountains and they will feel better after, promise. If not, you might just need to re-bleed.
I was hoping for a better review of the EBC reds... :thumbsup:
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
