Just finished Brembo conversion on my car
documented some details and so on.
and took alot of pics
Brembos Finally arrived
Closer look at the front.
With the Rest of my stuff
Slotted EBC rotors and EBC red stuff brake pads
Standard Front
Standard rotor vs new 324mm rotors
Fronts installed
The fronts where pretty easy and straight forwards but you must use the brake lines off the 350gt as it will be a straight fit
using the brackets
The rears needed abit of modification on the dust cover and the brake lines needed some custom mountings
dust covers designed for the standard rotors
Had to get a nibbler and modify it
Rear brembos installed
*the standard caliper blots coudlnt be used cuz it had a finer thread u can either use OEM Z33 or aftermarket caliper bolts
https://www.sau.com.au/forums/topic/288150-m35-brembo-brake-coversion/
So stolked to see that Danny! Its exactly what I have been planning.
Can you give me the part numbers for the rotors you used. Also did you need to to make a mounting adaptor for the rear calipers, or just make room with the dust tins?
Ben.
i can provide you all the part numbers
but only mod to the rear was the dust pan and different bolts
no mods were requiered to fit the rear
price wise would set u back 2.5K-3K
obviously i didnt pay that much for it lol
going to finish off blddeding the brakes today
so ill let u guys know how it feels
is there a chance youll have to upgrade your master cylinder?? else youll be pushing VERY far on the pedal before it grabs. might need to get the master from a brembo equipped V35 (if they are different)
too much movement..
it's not hard enuff for brembos
A larger piston master cylinder will help but if your pedal isnt too low, see how it goes.
Have you bed the brakes in properly? Go for a thrash through the mountains and they will feel better after, promise. If not, you might just need to re-bleed.
I was hoping for a better review of the EBC reds... :thumbsup:
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
