Stock- 296 x 24mm fronts
R32 GTR non vspec - scotty is very right - 296x32
R33 GTR - 324mmx30mm
taken from dba. don't know about minimums. There are some dodgy discs out there for sure. I'd say 2mm wear and its time for something fresh.
Noob.:P
You measured yours...?
guess what they are...
I checked the thickness when I put em on and before I bought em.....but next time I get a wheel off I'll check...pretty sure they are standard R33GTR...not the V-Spec!
http://nisoctt.forum...-up-information
Edited by Jetwreck
ok i lost all the info i put together and had to do it again :( LOL
same sized brake pad for all R32/R33/R34 and 350Z with the brembo's....
R32 GTR disc is 296x32mm with height of 54mm
R33/R34 GTR disc is 324mmx30mm with height of 53.8mm
350Z brembo's is 324mmx30mm with height of 49mm
Edited by WAGON_BOY
http://www.project-mu.co.jp/e/files/SCR_LIST.htm
P.S. Alex(PN-Mad) now has me thinking....I am really going to have to take off my wheels and check the rotor thickness...not admitting defeat yetph34r.gif!
I don't get what the concern with brake pad's is .....you have ????? brakes on your car.....ring a brake place tell em I have ????? brakes and what pads do you have to suit!
http://www.project-m...es/SCR_LIST.htm
P.S. Alex(PN-Mad) now has me thinking....I am really going to have to take off one of my wheels and check the rotor thickness...not admitting defeat yetph34r.gif!
meh... 2mm isn't too much to worry about anyway...
war have been fought over less...:pirate:
lol :teehee:
Let me summarise for wagon boy
when upgrading brakes you can do the following-
1)better quality original size pads and rotors
2)commercial big brake kit for G35/Z33
3)Z34 Akenbo kit ex US
4)r32 GTR conversion / possible upgrade to 324mm
5) z33 Brembo conversion
6) R33/34 Brembo conversion
between everyone here, all those have been done. std wheels won't fit- you need aftermarket.
most people worry about the fronts but not the backs. All will cost different $ depending on what you decide.
ive got the AXIS 18" rims im sure they will clear the callipers or is it the offset thats wrong???
cos i have a custom 324mm disc with RX7 S6 4spot callipers on my 808 wagon and i run a 16" rim.
Offset- the side of the 4 pot will hit the spokes- the diameter of the wheel is plenty big enough.
easist way to check - put a wheel on a z33 with Brembos or a R3* with Sumitomos
We know arx rims don't fit, my s2 17's dont fit - that being said, I don't know if ppl have tried the axis rim.
Edited by PN-Mad
lol :teehee:
use the AP big break kit for a 350z nuff said
Ap are up there as one of the best they make break kis for F1 for fs sake
Why anyone would need massive kits like those on the street I have no idea, best to keep the rotating weight down. I can get abs to kick in with my little toe with just 295mm disks.
Good slotted rotors and a good set of pads is what you want, braided lines will improve the feel. I got my r32 callipers for $300, the full set.
lol :teehee:
to be honest, i went with number 10] got some slotted rotors, and good qfm pads.
mine stops fine. and l can still get ABS on fine.
my theory is, if i change the brakes, and know that I can start braking alot later to stop, i'll over calculate and put it into a wall lol.
where as now, i know i have to stop a little early - i concentrate more.
+ me and scott were discussing this, and i rarely rely on breaks anyway
by no means sell the brembo's.. you already have most of the stuff(or the more important anyway) might as well just do it.
however, i honestly do think that the BC's and Sway bars are more important - but thats me, i rarely rely on the brakes, and when i do. they stop fine. the single piston is big enough.
Scott you never stop lol
The way your car is lowered you've probably lost the ability to stop it anyway :P
On a serious note with the standard callipers and rotors + only Nismo pad's I found the brakes pretty good! The R32 GTR Calliper and rotor set up was definitely better.....the Brembo's were better again....have yet to test braided lines!!
at least i dont blow things up lol. oh wait..
car stops fine craig. oh i gotta give you a call.
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
