Event is run by the WRX Club of Victoria.
Entries - http://www.wrx.com.au/motorsport/Entry_For...ctober_2009.pdf
Supp Regs - http://www.wrx.com.au/motorsport/Sup_Regs_...ctober_2009.pdf
Entry List - Click Here
2009 SAU Vic Motorsport Championship proudly sponsored by:-
https://www.sau.com.au/forums/topic/288196-winton-sat-10-october/
  • Replies 109
Entered :blink:
Zaver: Driver training is conducted on track within their own group. You can drive your car, or have an instructor from the club drive the car and show you what lines to take and how to get around the track safely. It isn't timed as far as I'm aware, but I could be wrong.
So what do u suggest i go for Driver training or the normal thing?? I just want a the maximum track time.. So i can get better.. Is there only a certain period for driver training or is it full day like the others??
And BTW are passengers allowed without a roll cage??
Well my entry is in.
and Remember Folks this is the last round of the Club championship this year, so if you were thinking of coming out to play now is your last chance!
Zaver, there are usually 5-6 groups during the day that take it in turns on the track, (to keep numbers at a managble level.) and cars are groups roughly by speed. plus one for Driver training. (this usually has the last number in it so less ppl on the track)
so DT gets the same amount of track time as all the other cars. plus cost less!
these days are run nothing like the drift days. we have a passenger session if there is time, otherwise it is just you and your instructor if you go for DT.
IF you are a bit unsure and want to get some pointers the DT is the way to go. your instructor can give you the basics you need like technique and lines and if you feel up to it and your instructor is on the same page most people usually end up going out on their own later in the day.
Ill be there, i think. unfinished business.
Well then i guess im in.. Will be going for Driver training!! My friend wants to passenger with me just for this track day , so do u guyz know any place where he can get a helmet from just for the day.. As after that he has no use of it!!
If you enter as a DT you will be allocated an instructer by the WRX club. This is your passenger for the day.
You can't just take anyone out with you.
The idea being that it is Driver TRAINING, so you will have an instructor to give you a few pointers and help you get a feel for circuit sprints...
As said before, there are often passenger sessions during the day that your friends can jump in your car for maybe one or two sessions..
Other than that it is only you in the car.... (Or you and instructor if you do DT)
I''ll get to the form shortly but count me in for this.
Provided I don't bin the car on Monday.
EDIT: Forgot to ask, do we need a cage to take a passenger at these days?
Edited by ActionDan
Without a doubt
Don't get caught on the street with that de-cat pipe. They are illegal and being an emissions related offense will carry a heavy fine.
Swap it on at that the track. There will be more than enough jacks and tools if you don't have your own :)
Edited by ActionDan
This passes:
It all depends on frequencies though, as some cars with a very deep exhaust note get pinged.
But yeah, 95DB at 30m is quite loud. I'm not sure if it is 95db though, as right next to it it says 75db... but the last Winton was 95.
Without a doubt
Yeah of course. I've heard it's some ridiculous fine for not have a cat. I might actually need help, I have a jack and stands but it cant lift the car high enough (with the bloody kit on it) to get under there.
Although this stupid front bar will be definitely be gone by then. Whether or not it's yellow or black still is another story.
Alright, you've convinced me. I'm in.
Driver Training and Novice class right?
Drive your car up onto two bits of wood or something first then you can put something on top of the jack to give you the extra height you need, also, be sure it's on stands to work on it.
Don't stress, with all the people there, we'll find a way to swap it out. Or if you're staying down there just do it at the hotel/caravan park etc and drive it to winton from there.
Oh man. I tried that once, the big nasty crack on the left hand side of the front bar is from me misjudging and rolling the car off the blocks and the blocks then catching the car by the bar itself.
I'm not fussed to be honest, I doubt it'll make a huge difference on my NA beast, but it'd be fun to make those fireballs :)
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
