33 ones don't :O
I got hold of a 3.5" Nismo system from a '33 GT-R, and the mufflers were both centre-flow, and the angles were all wrong (the length was too, but I expected that).
Some of the pipe was re-used, but neither of the mufflers were suitable, so it turned out to be pretty much a custom system.
Anyone want a genuine Nismo rear muffler suit R33?
:rofl2:
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4835982
just get one made at an exhaust shop, cost me $400 fitted for a mild steel 3" catback with resonator and cannon, dropped the car off in the morning picked it up in the afternoon
Was that loud? Mine needed 2 mufflers before it was quiet enough to drive without getting a headache from the drone in the back - although that was with a turbo-back 3" stainless system.
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4836205
yeah its pretty loud, plan on putting another resonator in to quieten it down
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4836225
I've got two big oval mufflers in my system (magnaflows) and it still drones from the back... though it was pretty *#$%ing loud after I fitted my dump pipe and it didn't line up with the cat, driving it to the exhaust shop with only one bolt in and a big gap between dump pipe and cat...
Edited by DaveB
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4836265
Yep saw the super drager one at $650 and thought it was too dear so got one made up at an exhaust shop and ended up costing over $800! (Another SDU member has since bought the super drager)
Apart from the one in the link above other importers will be able to order a Stagea specific exhaust for you.
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4836616
3" turbo back. no mufflers or resonators and I think she sounds like a gem! lol
haha yeah sounds a bit like a tractor off boost though... don't even know what on boost sounds like 'cause i never tried when mine was like that...
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4836651
I used a 32 GTR cat back also. 3" stainless dump ($150 off 33 on here), EXTREMELY high flow cat :D , $70 for cat back 3 1/4 " mild steel cat back one resonator+oval muffler, $70 to mod it to fit. = 290 Turbo back ;)
Jeez you did well. I did the same but I wanted a new or near new good quality stainless system.
I just bought a second hand 32gtr stainless 3" cat back for $250 (was pretty much new). He had a stock S2 stagea zorst there as well and when we lined them up they were pretty much exact however the 32 one was about 10cm shorter and obviously had lesser gradient bends.
So I took that plus a new jjr split dump/front and a new hi-flow metal cat to Rob bliss. It's getting fitted up as I type. I'm hoping it'll all come in round the $750 mark for the whole lot fitted.
Definately not the cheapest option, and I probably could've shopped round for a bit longer. But for practically a new high quality full turbo back stainless "3 system I reckon that's pretty good value for money. Still cheaper than buying a package.
Can't wait to see/feel/hear the results.
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4839823
The zorst is all fitted up. There's a noticeable power increase, my mate said "that's the biggest increase he'd felt in an exhaust mod".
Mind you it did go from stock to full 3" stainless turbo back with a split dump/front and 100 cell highflow metal cat.
It's definately louder, not too bad tho. Just a little drone at 2-2500rpm, but it's fairly silent when just idling along.
Back to the topic question tho;
They didn't have to bend the pipe, just had to move the brackets and extend it by roughly 100mm.
The split dump/front was for a 33 and didn't require any bending and wasn't fouling anything. However mine is a RWD which I think means there is less gear in the way up front??
There is slightly less ground clearance (to be expected), but it's a minor difference.
He did say that he was glad I bought quality gear tho, because he gets some people bringing in dodgy cheap crap that doesn't fit and they want it to be fitted for nothing.
So yes 32 exhausts will fit with a little modification.
Cheers,
Dave-
https://www.sau.com.au/forums/topic/288700-quick-question/#findComment-4841902
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
