Heyy guys just wandering if anyone here could install the blue led's in my dash and the aircon buttons, orr do you know anyone who could do it for a reasonable price please let me know :)
Thanxxx
Thanxxx
its easy to do mate just takes some patience to solder the new ones up, cause those are different bulbs then the plug in ones behind the gauges. did mine in blue a while ago.
have you changed the gauges to LED already ?
also did my light up ring around the ignition lock, and door panels
8 ,10 inch neons hidden in the front area and mutiple LED in the dome light in the middle. wired up to only come on with door open to be legal
gear shift selector LED to show what gear your in coming soon. and much more ...lol
I can help ya sometime but would be a few weeks out still????
Madaz did my LED's, no soldering required.
yeah you can do it that way too, I solder the LED and military grade resistor together not hack the wires or some shit like that.
the dude on here selling the LED's for lines on ebay can provide some too,,,, but they fail random. but he does provide replacements in the first year....lol
and DAMO your a/c doesnt seem to light up blue ????? do you know it has more globes hidden under the black panel ?????
dohmar likes to change his on regular basis to match the colour of the outfit he's wearing, maybe try him
gee maybe he should buy those colour changing ones... rainbow colours and all...hahahaha
Depends on the LEDS you choose...
Some leds wont require soldering. Others will.
I need my aircon ones done. And might as well do the dash ones, too.
Edit: Damo, you have quite a few dark spots on your dash lights?
Edited by CRoNic...
thats DAN666, i have those in my car, none have failed, and they simply screwed into where the stock ones came out!
my friend did have one fail, bad solder joint from his ebay ones...
Yeah i bought the ones from the guy on sau, shuld screw right in. I know that part is easy i just dont know how to take the dash appart and i know there are topics and posts about it all over the place but id rather pay someone who has done it before to do it so im not worrying about braking clips and things.
So if you or anyone on here could do it about 3 weeks down the track that wuld be good pm me about how much people wuld charge if anyone is interested in helpin me out :)
Thanx again guys!!!
A while ago i read all the way through his thread. It was a certain batch/series that were failing...something to do with the wrong voltage i think. He has now fixed them..i believe.
Thanx again guys!!!
the ones in A/C arent the right ones if there from DAN 666.. those are way too big for the A/C
can you take a photo of one LED to see for sure which ones you have??? the dash uses mutiple LED's on one stick if there from DAN666 ebay auction for R34 SERIES 1 if your car is SERIES 2 R34 they used different film backing on the clusters ,, much harder to light up !!!
Na mines a series one n its auto so i donno if thats makes a difference due to the thing bein on the dash showin u wat gear ur in its from zero point electronics on ebay he said they will fit and i just payed extra for the ac kit aswell ill put piks up in a sec jus gotta take one :)
+1. I have the same blue lights. I dont usually like stuffing around with cars much, So if I can do it you can do it . Was pretty easy.
I recently did all my dash with LED's from 666Dan. I did instrument cluster, clock, cigarette lighter, foglight, demister, headlight switches and also the climate control.
Pic of my instrument cluster here
Pack on the left has 3 smaller ones and 3 bigger ones of the same type and pack on right just has 8 of the wide angle ones all same size.
yep those are the ones you need, but to do the lights on the buttons on the A/C it takes 3 more little ones (hidden ones under the black plastic , screwed down) optional of course
and I used a single blue one for my LED on the ignition barrel. bright as fark now
doors take more customization if you want those done
it takes about 30 min to do the A/C and Dash ones
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
