A 3rd option is to install a different wastgate actuator and the good news is the R32GTST item is exactly the same as the R34 except the spring inside is set for 10psi. R32 actuators can be hard to find but I think it’s the best option for this level of modification as boost spikes and boost creep are eliminated.
I have used this peice of info in the DIY section. Bought a full Rb20 turbo and dumppipe for cheap as chips, swaped the actuators out in my R34. It should run 10psi without a boost conrtoller with no spiking & creeping, so I unpluged mine took it for a run & it was laggyish & only pulled around 5-7psi on my boost gauge.
My theory is, the wastegate is open just a little bit, which is letting out boost so im going to try adjusting the length of the pole going from the actuator spring.
Would anyone have any ideas on whats wrong? Or should I change out the actuator again to my stock R34 one & run the boost controller & sell of the turbo I bought & forget this idea ever was going to work?
Thanks.
Nick!
https://www.sau.com.au/forums/topic/289324-wastgate-actuator-problems/
i would try playing around with the actuator first to try and get it working properly first. but if you can't be stuffed then just put the old one back on with the boost controller
Can you open up the stock actuator? It looks like a sealed unit...
I think the actuator is running fine, im just thinking that the R32 gtst actuator does not have a 10psi spring after all.
But it seems to struggle to reach 5-6 psi, So maybe its not working.
it's probably stuffed mate, as you said you got the turbo etc for really cheap so maybe the guy was having boost control problems with it previously.
i would definitely try to get it fixed, avoid boost controllers if you can help it ;)
ummm, I dunno I checked out the turbo, no staftplay at all & spins fine.
The guy I bought it off bought the engine for parts for his other R32, so the turbo was not needed.
I can pull open the actuator with my hands, takes some strength but I can do it.
I hated my manual boost controller it spiked, creeped, droped off bost in high rpm, I just wanted this idea to work.
maybe try putting the r32 actuator side by side with the r34 one to see if they are the same size (length). you may just need to bend the mounting bracket a bit to make it sit a bit better and hold the wastegate shut better
get them side by side and pull on them both . 25t one is easy as . 20det one is quite hard . like i struggle to pull it straight out , have to jam thumb against bracket and kinda lever it to move it . it is possible the turbo you bought had a 25t actuator on it .
post a pic of it
I think my wastegate actuator is dodgy ... what's the best way of checking if it's working 100% ?? On some days I can hear the turbo spool up like crazy and car feels so unrestricted/crazy fast but most days I cant hear the turbo spool at all (even though my boost controller and gauge show im making boost) and car feels VERY lethargic
Is it cheaper to simply replace the wastegate actuator with a brand new one from Nissan rather than muck around with it? Mine could be bent slightly I think ... had some issues with it when I first got the car..
hmmm, That could be something to check, Don't buy a new one just go to a import wrecker & pick up a second hand one.
what type of boost controller are you running? Manual Tee peice?
if it feels lethargic, does it show your making boost? if so how much? You may have a bent actuator rod which could have it slightly open & letting pressure escape.
put a push bike pump on the hoses and see what pressure it takes to full open them both . a 32 actuator is a pretty fool proof upgrade . and ive never heard of one losing tention on the spring . we had one that leaked and it made tha car run 17 psi . i know of a few 25ts ive put them on and thay all run between 11 and 12 psi depending on fmic and exhaust upgrades fitted to car
does it feel "crazy fast" on a cold day and "lethargic" on a hot day?
If so that is your answer.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
