Guest RedLineGTR
Treasurer
Maintain bank account
collect membership fees and event fees
(if the Gift Recever status comes thru) issue reciepts for gifts and make sure proper amounts are transferred to the gift fund. Withdraw from gift fund when fundable task is to be carried out.
maintain the following records:
records of receipts and payments
GST tax invoices and income tax records
bank reconciliation statements
stocklists of merchandise and promotional material
We still have to talk to the accountant about certain things. It might just turnout u get to play with all the money :) lolz we'll have to see how much work the accountant will do or how much it will cost.
  • Replies 69
we haven't got gift recipient status so scratch that bit out.
Since snowman and a couple other guys were interested we could make them aides, where they'll be part of the decision making team, and they'll be called upon when any of the committee members are unavailable or have a full workload.
I dunno, don't want to start making positions up coz then it jus confuses the issue... but then I dun wanna discourage these guys either.
Guest RedLineGTR
Thats true..the current format is fine position wise. Until we get the club up and running then we can discuss if thier is a need for more positions.
just a thought...
why don't you make the positions an 'interim team' and all the people who everyone doesn't know can be some sort of assistants (as mentioned)
then after 2 months or so have the first AGM and then elect the final positions for the next period of time based on their performance in the 'interim team' etc.. make people earn their spot!
whatever happens, good luck!
well my understanding of a non profit organisation was that we don't have to submit a tax return as long as our earnings were less than $6000. Which it shouldn't be anyways. We do have to maintain reciepts etc for our own purposes. None of the money earnt can go to the actual committee and100% of it must be invested back into the members. As long as we do this there should be no requirement to be involved with the ATO, and no need for an accountant. But its always a good idea to get confirmation from him for now until its all sorted out.
Sound like everything is going well!!
Glad to see that there is actually going to be a commitee.
I would also like to get involve if I could to provide any support.
But as I'm still relatively new, I guess any major roll is out of my leauge.
Is there any pen pushing roles or PR roles that need to be filled?! :)
Definitely don't start making up positions for the sake of keeping people happy. If Al want the Vice Pres job the the Assistant Events is still available Im more than happy to do it but if there is someone deemed more appropriate there will be no skin off my nose. Im just looking forwards to the club getting going and meeting some more people starting this Sunday at Heathcote.
snowman how good will u be as a treasurer? coz we still need one of em. all you'll need to do is keep a tab of our expenditures and take off occasionally with our profits to the bahamas...
Even if u'r not of official position you're more than welcome to organise events etc and help out.
If no one wants the job then I elect NismoR34 as the new trasurer...
once we find ourselves a treasurer *coff* *coff* NismoR34 *coff* we should be set, and we can have a meeting. Till then yeah, try n find sum1.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
