Hey y'all! :)
Just wanted to share what I've done to my stagea
Basically just bought an infiniti G35 2003 model Stereo CD center console with navigation + DVD player and fitted it to my stagea.
Apart form that I changed LEDs to red, just something for myself.
Hey y'all! :)
Cool, so the G35 is obviously quite compatible, since you are viewing fuel usage info etc. I thought you had to re-chip the stereo... nice
needs modification? or straight fit? with all the navi working fine?
will i be able to get maps put on this unit? or same story again with no car in australia with the australian maps that will load on this unit?
same question..
i thought US goes by Miles not km's?
did you converit it over?
whats so hard about it. he had a navi car to begin with and bolted the USDM gear into it. the cruise unit came from me.
I wasn't :cool:
if you can put a band expander into it then you are pretty much done. out with one section and in with the other. the navi unit plugs in. there are a few spare leads left over from the TV side of things but thats it. the LED's - pass. too many and way too fiddly for the average punter.
only minor downer is the lack of AM. FM is useable.
chipping the radio was something I was working on and I cannot get the thing to stop drifting off the station..
Edited by Chris Rogers
still the same issue. no maps.
Aren't the US and JAP navi systems different though?
I thought that the Japan system is a Xanavi... not sure about the US system, but maybe something over here uses the same type of navi? Toyota maybe??
similar chassis though it runs a different software mapping engine to anything here.
vlad's idea fixed the most common bugbears of these cars. he did lose the TV option though. (I'm assuming he had it in the first place.)
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
