do you have the little tag with the number on it? you need that to re-order keys. it's a little alluminium tag that comes with the 2 keys. was your car new when you bought it in japan? it should have come with 2 keys and that little alloy tag. without that tag it's going to be a head fk getting a new key for it.
well if you have the tag with the number on it (nissan JP need it to encode the key correctly) then just buy one from nissan japan using the cars real chassis number. they shouldn't know whether or not the car left japan. and I would be taking all this up with whoever sold/exported the car for you. all 3 R35s I imported had 2 keys and the little tag/plaque for key re-order in case some got lost.
Am I correct in saying you need the r35 consult to code the key to the particular vehicle? ie All the keys are the same ex-factory and are individualised to the particular car via Consult. Nissan dealers won't help you but I do believe there is a Consult or two floating around Oz now in the hands of aftermarket....
not 100% sure, but the guys in japan told me you order the key, and then give the number that is on that plaque to nissan, that number is what they need to code it to your car. so you don't need the physical car to do it, just that code.
Beer Baron thank you for your help, do you have a nissan dealer in japan that can help.
From what i know the car need to have the consult equipment hooked up to the car to tell it to look for a new key.
Does anone in perth have a consult machine or will the cobb tuning port be able to do this?
tris
34s are completely different. R35s have a siemens prox key. no physical key. most 34 GTRs you just get a key cut same as any other car. the only difference is some have the immobiliser chip in the key (look for a red bit on the shoulder of the key) which links up with a reader in the ignition barrel area. it's a basic proximity based immobiliser. in that case you need the new immobiliser chip too. some also had dealer option alarms, but the keys are just normal keys.
anyway back to R35s and the guy with the problem, seriously the best guy to talk to is the guy that sold you the car. either the aussie agent, or the japanese exporter, or even the japanese dealer if you bought it new. that is your best hope of sorting it out. and no an access port most likely wont be able to sync up a new key. it only does some basic stuff like error code resets etc. not the advanced things that consult does. and no I don't know anyone in perth with one.
just to reiterate, seriously, speak to the bloke that sold you/exported to you the car.
Beer Baron,
thank you very much.
You right, the key needs a consult port but also a key code that is supplied by nissan to unlock the 'looking for key function of the car)
also if a nissan dealer is found to have worked on an import they will lose their rights to sell and service the gtr.
so we are stuffed at this point.
ta
the small tag is an international lock smith code.....You can read those numbers/letter to a lock smith over the phone and he can cut it and roll up and un lock the car........i have a key cloner here id like to shove an R35 key in it and see what it says....ive managed to clone the R34 GTR siemens keys....next step from that is to have a sniff around inside the immobiliser box......im sure something can be done (as long as its not a rolling code) as we have managed to flash and rewrite the all the japanese brand motorcycle ecu's for lost keys
tris
Try Steve Jones @ Fabcar in Vic Park ,he has a jdm r35(won targa west twice in it )he might be able to help you out
^^^Think you will find him at LF Performance now but I would try Ant @ XSpeed as I beleive he does all the tuning for the car(s).
damn i thought he and his family owned fabcar
i personally wouldnt go near xspeed after probs i had there a few years ago with my 32 r
Edited by gazza750
i will not be speaking to steve, he has had 20 months to supply the second key
hanson has the same issue with his 35 skyline
I would not go near them either, i hear you.
My JDM came with 2 keys and just checked it had the little silver tag with the code number on it too. The people who you got the car off would of recieved 2 keys, if they don't have it, someone must of lost it or thrown it away. Try that first, the 2nd key for me had the tag on it's keyring.
Don't know anything about keys for these things though, if you need a consult three to plug it into (aftermarket in oz) and you can't find one let me know I know of a place in QLD that have one, that might be willing to help.
Message me if you need that contact. I check the boards once a week though lately.
tristan,
i spoke to brad about it last night... he said they are the same as the maxima keys, asked if he could do it and he said yes using consult 3 but he talked to someone about doing it last week and there is no way in hell they are allowed to do it!
thats coming from a nissan dealer that isn't even a GTR dealer
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
