Car broke on the dyno this afternoon. Valve spring...
It made 460hp on 14psi before it broke. Obviously a lot of room left in it and the turbo was hardly awake at that boost level
Ahhh crap man!
460hp @ 14psi is amazing though.
Feel for ya Scottie I really do.
Hopefully that's all that's broken and that it can be fixed speedily
Ahhh crap man!
Hey Lith, currently its problem after problem. Long story short. It got back on the Dyno and burnt out an exhaust valve. Off the head came and has been sent away for some work. There has been some damage done to the guides as well. Head should be back to the tuner early next week and he has some seals to go in it also. Once thats done it s back on the dyno...
Its been a trying few weeks to say the least.
Man that's terrible luck :( I hope things start going a bit smoother from now on!
Car was finally ready Wednesday last week. Figure at this stage is 512rwhp on 18psi. Richard didnt want to push it too much as he didnt want to box to break. After the last 3 months of $$ spending I'm just happy to get it back on the road. Once i can afford to replace the gearbox then I will wind up the boost and see what it an really make. The torque in this thing is impressive
At this boost level the turbo still has a lot of room left in it.
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
