Hi
Anyone free this saturday to spend a couple of hrs with me. I may be coming over from perth to look at buying this M35.
http://www.sinergymotorsports.com.au/thumb...s.php?album=390
I'd need a lift from the airport to sinergy motorsports and back.. I will pay for petrol and lunch!
cheers
Wil
https://www.sau.com.au/forums/topic/290850-adelaide-stagea-potential-buyer/
I wouldnt mind a 260RS! but I gotta get an auto cos wife needs to be able to drive it...
I havent booked the flight yet, car is being inspected by Motacheck today, dealer recommended them - I hope they arent 'affiliated'.
There's usually a flight that arrives around 930am or the next one is just after mid-day, will let yas know cheers!
PM Sent with the details Will (didn't see your thread until now. Sorry)
I have been told that Synergy to actually have pretty good stock.
That Axis kit is not an option from factory for an ARX (as you will see in the PM).
It has been available for a considerable amount time (over a year I think) and $27k is too high IMO.
If I recall correctly, it has Tein suspension, but other than that and the Axis kit, it looks pretty stock to me... although I am confused... Where did the aftermarket screen go?
It was in the rear interior pic, but not in the drivers seat pic.
hmmm.
I was wondering exactly the same...
Looked like one of the "much more useful than OEM" Panasonic units, like mine.
hmmm.
Yep looks like the bose system. Doesn't the screen pop down into the dash?
It has definitely been lowered. The wheels may fill the guards but whats their excuse for the low (ie. non-ARX) ride height?
74000kms is pretty normal. Most freshly imported M35's I've seen are in the 60-80K kms ballpark.
25K seems a little high but then I'm not sure what AR-X's go for...they're definitely a higher spec than the RS and a notch up from the RX too if I remember correctly.
Got them down to 25k, still a premium...
It's advertised as Bose sound system...
Sales dude reckons its standard suspension but because the wheels on arx are higher profile it fills the guards better. :O
Does he realise that while the ARX has 18's as opposed to the RS's 17's, the ARX is also 40mm higher than an RS, RX or Axis?
Definitely check out if it actually is the Bose system. Bose and the standard integrated system look almost identical
Edited by iamhe77
?? I thought the standard integrated system IS Bose? There's another AR-X on carsales that has the same one.
Yeah they've got a silver axis there grade 4C with auction papers. K's are too high for my liking though.
I'm not too keen on the suspension being so low, i've heard teins can be quite stiff.
There are three audio systems.
RS gets the Clarion single DIN unit (which allows for the 3 gauge unit or storage compartment)
The RX and ARX all have the integrated dash, but it can be either the Bose option or standard unit (clarion maybe?)
I believe that the Axis models come standard with Bose... but I may be mistaken.
Edited by iamhe77
Hey Guys
thanks for all the volunteers to help. The car is in some sort of warehouse.
I paid for an inspection done by Motacheck yesterday.
The car isnt quite what i'm looking for so I wont go to adelaide this weekend.
Main thing is the suspension is so low it bottoms out over smallish bumps. Rear is unstable when driving... inside tyre wear on front tyres... in my opinion could have been a car setup for drift... could explain the replaced front bumper and rear tyres had much less tread left than fronts. Everything else about the car is good though I am a bit fussy.
Today I'm bidding on a grade 4.5 ARX with 28,000ks on it!
cheers
Wil
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
