well crank is back in... got my rods resized with ARP bolts and they go back in today... it should all be back together this weekend. with the crank i had it in and out no less then 15 times measuring and checking bearing clearances... we then had to do some work to make sure they were all spot on. time consuming stuff.
update!!
motor re assembled by myself.. bearing clearances checked. everything all good. and motor back in the car. started it up tonight after priming it up for oil pressure and it fired first go and sounded great! got it up to temp and it seems to have slightly more oil pressure then before and rev's and idles smoother then ever.
skid performed :P
some updates... been busy last few weeks working on my trailer doing brake upgrade, new hubs, GTST rims, new tyres, and a few other things. oh and new 4meter long ramps :D
in between i have been doing a few things here and there to my car. some pics here
10W super bright LED's with a 45degree spread. got these for the trailer which i will mount on my new nose cone facing backwards... it really is a PAIN in the arse loading and unloading at night so these will help a bit!
mounted a sheet of alloy for an understray cooling panel. simple yet effective.
and again
lock stops... had to do a two step part as it was slipping under the LCA on hard lock.
what the rim is scraping when on lock
machined lip lol
getting ready for ADGP next weekend
so my new brakes on the car trailer had a hiccup... i neglected to check hose to rim clearance.. and one rubbed thro. got f**k all clearance there not sure what i'll do.
another
my new ramps.. they are 4 meter scaffolding planks. they require a support in the middle to stop the sagging but they work a treat.
mounted light!
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
