with Bens and mine we have an extra gasket due to the adapter plate. we spent heaps of time cleaning all the gasket and carbon ect off the things. they are very time consuming. i have also pulled the complete intake off a GTR in the car chasing a leak. that is not a fun job.
who flocked your dash in the end?
i was reading in HPI that you can buy cheap flocking kits off the net. no one does it in norther tas as some of the rally teams used to send there dashes to the mainland to be done.
just noticed you dont run a hydro. never felt the need?
i had a hydro in the car when i bought the shell... did 1 track day with it before i ripped it out.. im not a fan of the hydro interfering with the footbrake assy. due to the way i drive with lots of braking/handbrake at the same time i just dont like it on the same circuit. In my KE i had twein callipers on the rear with an duel separate circuits.. that works brilliantly. Will be doing the same on the s14 soon. But really the cable handbrake with good pads works faultlessly
as for the flocking kits.. i got a local mate to do it for me.. he used an Ebay kit.
Loving the build, mate.
I have an S14 I'm building up atm as well, and the dash is cracked in a few places. How well does flocking cover tthe cracks? Or is a whole new dash a better option? It will be a street car, so quality and looks are quite high on the agender for me.
my dash was cracked before.. now i cant even notice it... it seems to have covered it pretty well! pretty happy with the outcome but i highly doubt the flock material is going to stand the test of time.
RBish: yeah the haltech has a inbuilt mapsensor, you can run up to 22psi before needing an external map sensor. as for the rewire.. its not for the faint hearted haha, im actually writing an article for drift battle atm on this very topic.
manifold is underway... should be finished very soon. its a work of art and a Garage 7 speciality item. it features a laser cut collector, equal length runners, a flange that bolts to either RB20/25 and Rb26 bolt pattern along with some other tricks..should work well!
well found the cause of death and overheating on the old set up... i went to wire up the fuel pumps in the boot and thought i would prime the surge tank so it was full before i attempt to start it. manually powered up the lift pump in the tank with 12v direct from a battery and nothing happens... turns out its dead as it can be.. so last few events it has been running off the twin 044's alone and the suction from those pumps draws fuel into the surge. crazy, no wonder it melted pistons!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
