Hi guys need a little help.
I'm about to install a WMI kit on my RB26 and would like to know from those who have done it, and i guess also from those who have good reasoning, where is the bestest location for the nozzle???
Its basically the stock piping with the oem recirculating valves, but i would like to place the nozzle probably mid way in the original rubber hose which is about 4" away from the intake chamber, but i am concerned that this might be too close for even distribution across cylinders.
My concern is that i want to get at least water/meth as possible in the intake piping so when the bovs open, there would be a minimal amount of water/meth being blown back into the compressor hence no damage to the wheels.
My other option would be on the pipe that exits the cooler before the bovs,but again there would more spray back into the compressors.
Your thoughts.
Thanks.
https://www.sau.com.au/forums/topic/291117-watermeth-injection/
Drill and tap into the alloy pipe approx. 50-100mm before the throttle body. My instructions say as close as possible to the TB, but I put it back to 75mm to allow a bit better swirl mix before it goes to the cylinders. Works for a Gtst anyway.
both of you guys have rb25 (single throttle body) so its abit easier on placement choice, rb26 = itb(6)
smell how were you going to place it into the rubber pipe? make/buy an hard inlet pipe with a fitting?
Would it damage the compressor blades? it would circulate back into the inlet pipes of the turbo and turn into vapour?
I've ordered a kit from the states and was thinking of installing it into the pipe few inches past the exit of the intercooler in the inner guard, or just before the plenum intake, the pipe in the engine bay but I have made all my piping out of alloy, so installing will just require a bung welded in.
how many nozzles did you get aswell? could place them in multiple positions?
I see we are in the same boat!!!
The water can cause damage to the compressor blades over time thats why most manufactures do not recommend u put the nozzle before the compressor.
I am only going to use one nozzle but there are guys here that have used two, usually one before the cooler to aid with the cooler efficiency and one after.The problem with this though is water can puddle in the cooler,.... but again i can only go on what i have heard.... or read.
Come on guys, what do u recommend for the 26 ????
Nozzle before the cooler is stupid. U want to keep the air hot before the intercooler so the intercooler actually has something to do. The hotter the air, the more heat the intercooler can remove. In theory, just after the intercooler is best but the insides of the piping get droplets of water everywhere. In practice, the best place is about 100mm before the beginning of the plenum (where the throttle body would be if it had a single). DO NOT mount on the plenum or it'll have extremely uneven cylinder distribution.
Yeah, but the theory is the same.......
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
