and you thought gordos bad luck had ended....
well guys it seems that he now has a new silver drivers side door that we replaced last nite after a truck almost took the old door right off
im sure he will tell the story in more detail and with pics he took
i hope this badluck has ended now for sure
goodluck gordo
Thats farked up gordo.
I got more bad news for Gordo. The QLD government is following the vic tosser labour government and putting in a whole lot of fixed speed cameras in Brisbane and Gold Coast even tho the vic ones were found to be faulty.
Looks like the qld premieris even more of a ***wit than bracks (if that is possible)
yeah gordo is ok guys
he stayed at my house last nite like we sorta planned already, fixed it up last nite, now hes in dubbo stopping over for the nite
also it looks like he will have to replace the drivers side front guard too as its a bit too bent from where the door slammed into it
we got it pretty good for the rest of the trip tho
JEEBUS! - I think there's a Victorian curse out on that car. Glad to hear you OK - but sh*t, we wanted to hear tales from your trip involving Danish hitchhikers in bikinis - not this.
Hope the rest of the ride is super-uneventful.
hehe.. nah, don't want to sell it at this point.. its too much fun having a car like that around here, and these things are when i'm *not* being stupid which sucks the most. Panels can easily be replaced. Anyhow, here are a couple of pix. It looks better now with the door at least. $600 and it should be good as new, could have been worse.
Shouldn't have stopped on the highway - stupid i know, i should know better and i've done plenty of highway driving before. Just one of those things. Stopped 'cause i thought i heard a ticking noise, and also thought i'd check the oil, water, etc. Unfortunately i just left the door the slightest bit open, not even what you'd consider that open and i was only there for a few seconds. Car wasn't parked that close to the edge of the road either. This huge road train (double semi - huge ****er!) comes by, i think "jeez, thats big".. and as the 2nd "carriage" goes past, the backdraft rips the door forward a bit. I can't run back to close it or i would have got slammed myself, and then wooosh.. before i know it the door blows out to right angles and SMASH.. rips the window clean off (goodbye tint.. meh, it was scratched anyhow), bends the door into pretty much an L-shape, and buggers the door trim. So I'm just in shock at that point. Truck just keeps driving, not sure whether he heard or just didn't give a shit (i think the later). So about 100km from Albury where i was meeting with Kamikazee to drop off his amp, don't know what to do so, **** it, i get in the car, and cruise down the Hume for 100km holding the door with one arm and driving with the other.. hoping like hell no cop makes me get it towed ($$$$), but i was lucky and about an hour later (going 110km/hr like that..lol) i make it into town, with everybody looking strangely at me.
Just watch out if you're ever on the highway, 'cause trucks couldn't give a flying shit about any car. If you're in the way you're just a hassle for them.
Can't thank Kamikazer33 enough for helping me. Without him, would have really ****ed up my whole trip, and I wasn't holding much hope of fidning a 33 door, and was thinking one would have to be shipped up, etc but it did work out and i didn't lose anytime in the end. There was a good Japwreck place Justin knew about, so we went there and they had all sorts of half cuts and stuff. We put the door on that night, and its been fine ever since. $300 for a whole door is a bargain too :rofl:
Anyhow, i'm here staying at my mates just back from Broadbeach until i find a place to share in Brisbane. Its awesome!! Some slight damage to my car doesn't really worry me when i'm doing what i really want to do with my life..
hey hey gordo, haven't talk to ya for ages. wat's this QLD business?? holiday or u going to live/work up there now??
anyways, glad to hear fixing the door wasn't too big a problem. I thought it would be a problem too, being that u were in albury, but all's well that ends well. :rofl:
good luck with the plans u have.
chinny.
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
