So with the help of Luke and a few others today we got the gearbox out of my car to try and find out what was behind the bad grinding sounds and gear selecting problems. As soon as the clutch came off the reason for the grinding sound was pretty clear. The clutch centre was rubbing on the bolt heads on the centre of the flywheel. Im not to sure what caused this to happen but im very happy that the clutch didn't explode at the time attack on monday as the result could have been pretty bad.
I'll have a look on here to see what i can find but if anyone has any hook ups with clutches let me know. Gonna go for a twin plate this time round, need some thing thats good for 300kw+
https://www.sau.com.au/forums/topic/291411-clutch-fail/
  • Replies 55
Posted Images
Woah! Lucky it didn't let go at the time attack.
Glad to hear you caught it just in time. Didn't look like it would have lasted much long.
and +1 to never seeing a clutch like that before. :)
https://www.sau.com.au/forums/topic/291411-clutch-fail/#findComment-4873255
Kubos motorsport, do good GENUINE Exedy clutches, all parts branded Exedy, not mix and match crap. Talk to him, very helpfull, good quality and great prices. There are some RB25/30s running these clutches, i'm pretty sure cubes was impressed with his.
https://www.sau.com.au/forums/topic/291411-clutch-fail/#findComment-4873314
Pretty clear that the clutch centre let go 1st and then bowed out against the flywheel bolts......obviously bolts need to be replaced now regardless if they're still tight.
Seen clutches like that before....usually caused by hard launches or flat changing causing the centre to over flex.....also if it's excessively tight over the splines during release.
https://www.sau.com.au/forums/topic/291411-clutch-fail/#findComment-4873390
The springs probably bottomed out also, causeing shock loading which made it crack. I'm no expert on clutches but I know my metals, those cracks look like a combination of high temps and shock loading.
I was just saying the other day at vilis that i didn't like those clutches after a bad exerience I had with mine.
https://www.sau.com.au/forums/topic/291411-clutch-fail/#findComment-4873437
i could probably get you an os for a decent price.
If you could find out that would be awesome, I'm after a twin plate to take 350-400rwkw and lots of track use. Also need it ASAP!
Cheers!
https://www.sau.com.au/forums/topic/291411-clutch-fail/#findComment-4876533
True twin plates are never going to be as good as a single for very quick gear changes as you're attempting to release 2 driven plates as opposed to 1.
However, we don't have a drag strip and grip racing doesn't require the lightning fast changes that drag racing does, hence why I went for the Coppermix Twin plate......which in actual fact, is not a true twin plate (ie. with intermediate plate) cause it uses a single sprung Boss Drive. The other reason I went this way is cause of the lighter diaphram that you can get away with and still get a greater clamping pressure.
I've never ever liked solid centre style driven plates or the metal button style ones either cause they're not forgiving as a daily driver. Also double diaphram pressure plates used to be the rage years ago but your left calf muscle needs to be bigger that your right, lol. Drivelines also hate these 3 style of setups.
https://www.sau.com.au/forums/topic/291411-clutch-fail/#findComment-4876582
yeah I had one let go in similar fashion , opened up the pressure plate to find shrapnel inside it on my RX7, Aluminum flywheel / Center force racing clutch
make sure you check the run out on the flywheel, bet it could be borderline to thin?
also check the bearings on the input shaft ,always replace the center pilot bearing, you call it something else in OZ. but it goes into the crankshaft?
good time to swap out the seals on the input shaft as well ?
and if your real bored polish the casing to mirror finish..hahahah
sucks mate but least your floor doesnt have a hole in it from the flywheel
https://www.sau.com.au/forums/topic/291411-clutch-fail/#findComment-4877746
Scopot Bush?!
Edit: Damn word filter, i mean one of these - i bet the word filter messed with the link.
Edited by Aberax
https://www.sau.com.au/forums/topic/291411-clutch-fail/#findComment-4877991
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
