i know we've all been waiting patiently for another cruise.thanks to adam for organising the last one(even tho he didnt show and craig,aleks and myself took over)
i hope everybody enjoyed the drive,they are some of the best roads i know down that way
some of you may know i love all things rotary,and ive owned my fair share of mazda's
heres what id like to do
SArotors.org is holding their club birthday cruise,and id like us to join them
im sure there will be some tough old school rotors out for such an event
the cruise has been set for sunday 8th november at 10am at ingle farm shopping centre
if anyone from down south want to meet up for a coffee in glenelg on their way thro to the meet spot,let me know or wants to meet up and drive up there together ill be more than happy to work it out with you
if anyone has a major problem with us being on the SArotors cruise then pm me and ill be more than happy to discuss it with you
ill be going either way
thanks everyone
peace,love
rodney
Edit by Mods as per request of -RBD2- :
SArotors have decided that "defectable Nissans" won't be welcome on their cruise, so plans are changing. The date will remain the same (November the 8th), but the location will be revealed via PM, so please send one to -RBD2- to get the details...
https://www.sau.com.au/forums/topic/291427-adelaide-stagea-meet/
thanks for that nick,much appreciated
anyways after doing the right thing and asking the SArotors members whether they would mind us tagging along with them,their main concern is having defectable nissans hooning around in amongst their cruise.
id rather not argue with them as im also a member on their forum.
pm me your phone numbers and ill get the details out to you as soon as the route has been sorted
will be talking with adam,craig and aleks soon to work out an awesome route for the day.some of the previous cruises roads maybe included....
sorry for fark around people,we will be well organised.if its a nice day,my BBQ might even be in back of the wags for our lunch break
cheers lads
rodney
nevermind craig,with the weather slowly getting better hopefully we can all get together abit more often
anyone whos number i dont have can sms me 0421754575
and once the finer details are sorted,ill send out the messages
the day will involve a late morning meet and drive,break for a BBQ lunch in a nice spot,then the trip home
had some very good roads suggested too...
will be a good day
^^not too sure what you mean brendo,comparing revs to power maybe..?
had a nice little drive yesterday with some of the lads,on some roads that are new to me
so i might try and incorporate some of those roads into this cruise
alright,roads are organised.lunch break will be at a nice bakery and the meet point is sorted for 11am for a coffee if anyones keen
details wont be posted here so send me some mobile numbers if i dont already have yours and ill put the sms' out in the next couple of days
cheers everyone,see you sunday
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
