hi all
following on from my earlier thread http://www.skylinesaustralia.com/forums/Pu...ag-t289922.html
i have just found out that my Stagea landed in Australia last Friday
however, they also told me:
1) the timing belt was on its way out, so they're doing a full service (including the belt, fluids, spark plugs etc.) for free
2) it has dual sun roofs :P
3) the xenons had to come out (but i think they can re-install them, for a fee i assume :( )
what else should i be asking/checking?
have been through this http://www.skylinesaustralia.com/forums/Bu...n-C-t92065.html , is there anything else?
item 1 is a bit of a worry, given the car apparently had 52,xxx km's on it, so i'm assuming that it's been wound back? or could it just be that since it's so so old (and apparently was hardly driven), it could have deteriorated of its own accord?
probably heading down on Friday afternoon to check it out
as noted in my earlier thread, my deposit is fully refundable if i choose not to buy the car. hoping this isn't the case
thanks all
https://www.sau.com.au/forums/topic/291621-my-stagea-has-landed/
Timing belts are good for 120,000km so speedo has probably been wound back. Normally a low km can be backed up by service records so their absence would be an indication but not proof. However if the car still looks good and value for money no reason not to go ahead.
Ask for all the bits for the headlights and tell them not to cut any wires and you should be able to reinstate them yourself.
How do they know the belt is "on its way out"?
re. the xenons... they can be butchered in so many ways... make sure they don't cut any wires. They're dead easy to put back if you don't cut anything (and as long as they don't keep any parts, ie. the globes or the ballasts, which are the boxes which drive them - one per headlight - and removable separately to the headlight unit).
i'm not sure why they decided the timing belt was suspect, but i guess it doesn't really matter, given they're doing a full service on it at their cost (i.e. belt, spark plugs, fluids etc.). the one thing i will be checking thoroughly is the conidition of the interior, to see if i can gauge exactly how many km's it actually has done (assuming somewhere around 100,000)
in any case, the new timing belt should be right for another 100,000 km's or so, right?
not sure what they've done to the xenons. they said they had to take them out, but when i asked about them, they mentioned something about "come in and we'll chat about them"
am heading in hopefully on Friday afternoon to check it all out
If the kms have been "wound back" (ie. had the dash swapped) - the importer will know for sure....but I doubt any of them would admit it.
The odometer is digital so as far as I know the only way to "wind back" the kms is to swap the dash with another car that has done less kms. Unfortunately it is very common practice in the industry and you are best to go by the overall condition of the car.
If you know they've bought the car from auction, ask for the auction sheet. Simple. Watch their faces carefully when you ask - if they say no or hesitate, then check the condition of the car very thoroughly.
Actually there are plug-in devices in Japan that can wind back a digital odo... unfortunately.
i'm not 100% sure they bought from auction. is there any way to tell?
according to this thread - http://www.skylinesaustralia.com/forums/Bu...n-C-t92065.html - i'll be looking for:
* Rust and/or paint bubbling and peeling under the door wing mirrors;
* Rust around the strut towers, where the strut tower brace is bolted down;
* Rust and/or paint bubbling and peeling in and around the sunroof runners (if fitted with a sunroof);
* Condition of door seals and rust where the seals attach to the body;
* Rust on the door and boot hinges;
* Rust in the spare wheel cavity...
they're doing a full service, so oil and fluids should be OK, can't hurt to check though
what else should i be looking for?
who knows whether the 52,xxx are genuine, but anyway i'll have a fresh timing belt which will be ready to rock for the next 100,000 kms or so
wondering whether to get a pre-purchase inspection done?
i.e. compression test etc.
this will cost ~ $350 (i think), which i would normally say is worth it, but the car allegedly comes with 12 months roadside assist and 5 years warranty
so if anything major breaks, it should be covered
but i don't really want anything to break do i?
plus they're doing a full service, with timing belt, fluids, plugs etc.
decisions, decisions
Your warranty will only cover specific things up to a certain value
check here
http://www.247roadservices.com.au/extended.htm
check here
ah, cool
thanks for that :down:
i assume they just get the cheap one? (i.e. Plan A)
might start making calls to State Roads/NRMA etc.
cheers
Autosport @ kirrawee are not far from where your going, they could be good to use for a checkup.. they have a pretty good history with me and my nissans..
thanks mate
car is from a dealer, so not sure they'd let me take it to Kirrawee
will keep them in mind for future servicing etc. though
have been thinking of AutoSport or CV Performance at Taren Point
Just a warning be very careful with 24/7 Road Services and state everything that is going to be done when it comes to repairs of they screw you over...
When my Transmission blew up i took it to a Transmission guy who took to for a drive and he confirmed it was the transmission. Rang 24/7 and told the young lady the situatation and asked if it was ok to remove the transmission myself and send it off to the transmission place to be quoted and when 24/7 give the go ahead to be repaired. I was told this would be fine and wouldnt void the warranty so i removed the transmission and sent it off to be inspected... A few days later a Supervisor rings me and tell's me the information i was provided was incorrect, the transmission wont be covered as the car has to be present at the transmission place and wasn't removed by them...
So i had to pay over $2000 out of my own pocket to pay for the transmission due to their own stuff up!
Edited by SHIZNT
also, a question
the State Roads inspection says they do a balance test of the cylinders, but not a compression test
so this means that if all cylinders are running at say 80%, it will pass the balance test but would not pass a compression test?
thoughts?
Just a warning be very careful with 24/7 Road Services and state everything that is going to done when it comes to repairs of they screw you over...
When my Transmission blew up i took it to a Transmission guy who took to for a drive and he confirmed it was the transmission. Rang 24/7 and told the young lady the situatation and asked if it was ok to remove the transmission myself and send it off to the transmission place to be quoted and when 24/7 give the go ahead to be repaired. I was told this would be fine wouldnt void the warranty so i removed the transmission and sent it off to be inspected... A few days later a Supervisor rings me and tell's me the information i was provided was incorrect, the transmission wont be covered as the car has to be present at the transmission place and wasn't removed by them...
man that sucks!
i guess with those sorts of things, you need to get it in an email/writing so they can't screw you over!
for this dont just look in the cavity. look under the car between the fuel take and the rear of the car, that is where mine is starting to rust, and its only noticeable from the underside of the car.
sweet, thanks mate
i've organised a State Roads inspection anyway, for my peace of mind
http://www.stateroads.com.au/
getting pretty excited
cheers
they've cut wires :down:
apparently i'll be getting all the bits and pieces that they took out
how hard will it be to re-install?
cheers
Is it true they are required to keep the auction sheets by law?
and also are you as the buyer permitted to view them?
I bought an s2 a few years ago from a dealer, and when I asked about the auction papers they said they dont keep them. Months later I was told they are required to keep them. I have good reason to believe the kms wouldn't have matched what the auction papers said...which would explain the secrecy.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
