  • Replies 14.2k
anyone know about the R32 steering wheel and how many things you need to remove to be able to take it off. I just need to simply move it over to the left a few notches grrr.
stock wheel or aftermarket?
gotta take the horn off and then use a certain type of hex nut to remove the retainer bolt - not sure what tool or what size it is to remove it (im no mechanic) but its not too hard. assuming your wheel isnt quite lined up to spline 0 and ur hicas is wigging out?
-D
will r33 radiator fit directly into r32? and is it upgrade?
if you're looking for a good upgrade, the isc 52mm is the biggest u can fit in the 32 without modifying the fan and shroud
I love mine ;D
it keeps me warm at night
-D
sorry man would be down but i picked up a ankle injury during my last game. Dr says ive damaged ligaments :D
but i got a rebound and scored when it happened so that makes it worthwhile right?
apparently the treatment is R.I.C.E. so ive installed neons on my foot and trying to incorporate crome
Edited by Inline 6
how your ankles? im a bit worried it might not be the same again for a long whiles.
sh*ts got me feeling old, felt like wolverine as a kid. sh*t would just heal in a day. now i gota worry about breaking my hip every game.
Edited by Inline 6
welcome to my world, bitch.
-D
Shiny new Wasteland, I see... :D
I've got a chip in my windscreen and I want to get it fixed. I've called O'Brien up and they said they'll repair it (probably with that glue-type stuff) for $116. Anyone know of any other place that might do it cheaper? The car's going on sale soon so I need to get it done ASAP.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
