  • Replies 14.2k
What size rear has the turbo got Abe?
I think the Garrett 3076R(3037S) is a 0.82
little bit of a lean spot there at 160kph....just monitor your knock count
Are you talking about the 262kw graph or the 149kw graph?
If the 262kw graph, if i am not happy with the tune i can take it back and get it touched up for free :), he didn't really have much to go with as it was a whole new tune, so he got it to where he was happy with it and gave it back to me. If there are some niggle bits i am not happy with, he will sort it out, see how we go on the way to Loxton. But i will rarely be driving at 160kph, if at all.
u can see the lean spot in the first 149kw graph that you posted. there is a big drop in the afr line.
ur new tune looks good :)
Ah...well the 149kw graph is stock...stock everything other then a podfilter.
just bought an RB20 + gearbox + FMIC + ecu, afm, loom +3'' zorst for 1100.
bargain? yes.
entirely happy? no its missing .5 of a liter in capacity but oh well, its a budget build.
specially when its gettin fitted and wired by a effing champ in swaps for the RB30 :)
cant wait.
pretty keen to build it up in almost every area, inherited some pretty average suspension in the car so probably looking at coilovers as my first upgrade. gunna go for the BC br range i recon, cant seem to find any negative feedback on them and they are sweet price.
buy decent quality straight off the bat. please. save for an extra week or 2 and buy cusco's or something.
.82 rear, thats why its a bit laggy, but u got more topend out of it
since u cant check ya knock level reading just keep an eye on ya engine warning light, if it starts to come on regulary after a boosting hard step off and getnya tuner to check everything again (timing)
bargain? yes.
cant wait.
nice deal Graig
and who is this CHAMP that is wiring it up for u??
fair enough, might have a look into it a bit further. im normally pretty keen to do everything the right way. to me these coils looked like a fair deal.
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
