  • Replies 14.2k
who here has the mate who works at Grand Auto??
they have an RB30ET that i want moar info on NAO!!! hehe
Anthony (Chuck) Norris (owner of Grand Auto) and I used to work together at Adelaide Engine.
Tell him your a mate of mine and he'll look after you Craig.
ooohhhh yeah, ill be hooking up the ''pete, your old mate sent me''
hahaha. srsly tho he has a nicely set up 30et that i want to chat to him about, im heading up that way tomoz
for work so ill prob just drop in, easier than over the phone.
thanks pete.
oh btw, remember what we spoke bout few weeks ago? bout me recovering money owed to me?
all good now, did it the right way, 2 days later had the full amount in my acc :thumbsup:
Well my Maxima plans may have changed
http://www.carsales.com.au/all-cars/privat...s=&__N=1216 1247 1282 1252 4294963846 4294963593 901&silo=1011&__No=45&seot=1&CT=Compare&__Nne=15&__sid=124A2A3AA132
Me likey veeeerrrrryyyy much :thumbsup:
So who can weld up a crack in my 26 plenum cheap and also port out some exhaust manifolds? :thumbsup:
welding a crack in a plenum is bad news. i daresay thats why u got the engine cheap.
do urself a favour and source a nismo plenum from somewhere. theyre stupidly expensive retail but u can find them cheap sometimes, and they will stop cyl6 leaning out - perfect for your power figures too
gives u an excuse to put some am performance exhaust headers and dumps on it too
-D
The Crack is only small Ben and dont really wanna be forking out big $$ for something that wont improve anything.
I'll be in touch Chad. Hopefully get this motor in before the end of year.
thank god. lol.
well well well !
engine is all bolted in !!!!!!!!!!!!!!!!
all i need to do tomorrow is
hook up ECU
hook up EFI lines
Bolt tailshaft in
Put o2 sensor and front pipe in
put AFM and pod on
put gearbox oil in
put engine oil in
and im done !
hopefully put some rego on the car tomorrow and go for a blast tomorrow night
That GT-R's not too bad there James just majorly dislike the interior retrim and its done in vynil eww.
Get that interior out and good cond. genuine GT-R trim and your set. DO ETTTT :)
_____
On another note.
I got my clutch - Freshly machined flywheel - redline gearbox oil - new transfer case oil - rear main seal - C's short throw shifter - scopot bush. I just need someone to help me do it :thumbsup:. Any takers lol? Can supply beer and some $$ for your efforts? and of course I can help with some things lol :(.
Edited by Weezy
thanks pete.
ahh, that's very good to hear Craig.
It's all for the best that this person can be involved with you guys again.
that wont improve anything??!?! i think u have that slightly wrong.... =\
I'd probably weld it too if it can be done successfully....forking out $1500 or more for an aftermarket job just to gain approx 5rwkw aint worth it IMHO
dale,
ill take the seat if craig doesnt want it!!
And i have just replied to a PM from Ruby so between the 3 of you someone can have it for $170 i'll let you guys sort out who gets it.
If Chad can't help you out Luke, i have a bloke who does my welding and he is an Aerospace certified welder (i'e he certified to weld planes and such) he had a full time business doing mainly stuff for mines but fits me in when ever i need something delicate done ( i have a MIG for the not delicate stuff). The only thing is he's up at Elizabeth West.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
