  • Replies 14.2k
get a job u bum :) lol enjoy the gov sponsered holiday for a lil bit first though
No can do champ, cause we got a package the government won't give us any money....Depending on how many months/years worth of package you get is how long you can't get centerlink for...
least they did it on a nice day - he can spend the next week at the beach heh
-D
Cairns beach as well all things going well :D Was meant to finish friday but they ended up working all weekend cutting machinery up and will be for another 3-4 weeks to come
Did they send anyone out to Nylex Fuel Tank Systems?
Nope, no transfers anywhere, fuel tanks has been sold to a chinese firm pending government approvals....How you know about nylex and FTS???
Wow. Parts for the RB26 are so confusing. Everyone recommends different things and plays down the use of others.
:D
it aint just 26's its all car stuff, people have a bad experience with something theyll flame it good :) there is always a possibility a car was about to blow and it was just a coincidence you changed engine oil around that time etc
Yeah no shit hey. Trying to find out about catch can setups/ oil mods for some piece of mind and just when I get some useful info someone two posts down trashes it.
All I want is a lightly tuned reliable GTR.
  • Oil mods like which catch can, relocator and oil cooler
  • Front pipes (No I'm not going to AM Performance
  • Pods or panel filters
  • clutch, ebc, injectors, cams, fuel pumps.
Too many options, too many chances of buying a brand thats not going to work well.
Sometimes doing a bit of outside forum research might be good too....just putting it out there....go on the manufacturers website's and try to find out more details etc
Can get non atmospheric nismo type catch cans with a clear tube bolted to the side, they work quite well. Keep it non vented for regency reasons. I got the greddy cooler and relocation kit, its quite good and you can choose where to mount the components.
Front pipes - if you wont go to AM performance (ive not been a customer but his work looks impressive) then some stock r34 gtr dump pipes will do you well, otherwise u can talk to Mark @ Exhaust Tech (he fitted my junbl resonator and mufflers)
Pod filters are my personal choice, esp the 3A brand. They were rated first in Wheels magazine 2 years ago and they beat reputable brands like Apexi and others. Theyre $25 each and are a dry filter, meaning it wont clog your AFM's up.
If you're going mildly tuned, forget the cams and dont worry about the clutch until yours starts going... I have a greddy profec B spec (type 1) which is a brilliant controller, however again it comes down to personal preference. You'll only need a fuel pump and injectors if you're planning on going over 300kw, and you'd need better (non ceramic) turbos before you consider boosting past 1 bar. However that said, if you want injectors I can get them cheap from the USA, and the nismo fuel pump is one of the best replacements out there for GTRs, simple direct replacement with no mods of the fuel cradle necessary.
depends on how hard u wanna go on it really, and if your wallet is endless
-D
Manufacturers websites will tell you everything a product claims to do and nothing it doesn't. You also wont see any bad feedback.
Yeah I was talking to Dohmar last night about this sort of thing, and while I get alot of guidance from the forums, I also ask my mechanic and tuner who both have extensive knowledge of modifying imports also.
See. Thats what I miss about the dirty 20. Motor was so cheap I couldn't really give a f**k if it goes bang. Now I'm like.. wow.. if this motor goes pop, that's a whole lot of f**king money.. So I wanna do everything I can to prevent it..
Good mod list damo. Now just need the $8k to buy it all haha
not bad but theres ways to save money
http://www.carbonblack.com.au/buy-car-part...filter-202.aspx $25 x 2 is much cheaper than the Apexi airfilter kit, and the 2nd filter damo linked is simply a replacement element for the stock airbox.
These injectors http://justjap.com/store/product.php?produ...=310&page=1 are typical jap aftermarket price, however you can get Siemens Deka injectors (From 300cc to 1600cc) for around $360 for a set of 6. 700cc is way to big for a street car, you'd only want 700cc's if you're planning on going over 400kw. 575's are big enough for most street cars.
Yes GTR's are bloody expensive but the trick is to replace stuff only when you need to, and do a minor upgrade when replacing said component. Shop around, you'll be surprised just how cheap you can get quality parts for - while I like justjaps range, they're a little bit expensive for some of their items (those dumps they have for example can be fabricated by AM performance for half the price, and he'd fit them for you too)
-D
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
