While we are on quick questions lol
Im looking at getting an RB25DET engine package that used to be an auto, will this matter for me? (going into R32 as a manual) I know you change the flywheel etc but what about the ECU...
  • Replies 14.2k
you can use an Auto ECU with a Manual but not the other way around. The only thing that will be a pain in the ass will be getting the auto sp.i.got boss out of the end of the crank but it can be done. you will probably need (well it'll be easier) a manual loom from the trans to the EB relay box but you can adapt the Auto one if you want to.
Quick question..i know you can buy a trans cooler for your auto..can this also be hooked up into a manual transmission?
As for the Trans cooler question, no you can't because there is no pump to move the G/Box oil. With an outo it is basically a big pump so there is a pressure feed to push the fluid through the cooler but with a manual they rely on contact transfer to move the oil through the box and there is no pump.
In race cars that need a cooler in their manual trans's they run an external pump to move the oil around. They also run a thermostat as the oil needs to be allowed to get up to temp.
Why are you thinking of fitting a cooler to a manual trans, they don't need it unless your doing long stints (1hr+) on the track?
Edited by D_Stirls
Thanks DStrils, if I get that one I may aswell just get another loom because they are pretty cheap. The reason it caught my eye is auto and 81k say tight motor to me...
edit: Had an epic dumb moment, its late ok :D
the engine looms should be the same it's just the loom that runs down the drivers side of the engine that the alternator, oil pressure switch, transmission etc run of that's different.
Edited by D_Stirls
Main reason would be just to keep the manual box nice and cool. Im not exactly awesome with a manual, due to lack of experience, and wouldnt mind having some kid of insurance so i know that the box wont be rushing hot oil and such. I was just thinking this because i remember seeing the trans coolers on the gtr z-tune, and whilst looking pretty scmick, makes sense to me.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
