  • Replies 14.2k
Yeah what I meant in that comment is replacing all three. Instead of having 2 or 3 gauges around your dash, just replace the cluster with something better
Can be done if you're willing to shell out the bucks
Writeoff has a very comprehensive set of gauges in his centre console. Maybe he can find you a pic if u ask nice.
He's running Defi's which as talbo said, arent cheap, but they do look gnarly in an over the top riced up way
-D
ah hah finally found them :P seen these on tv ages ago.
http://www.vintagecarradio.com/store/index.php?cPath=1
awesome for anyone restoring an old car and wants a half decent stereo without spoiling the classic look of their car
n wayne i dont think they are the same they look slightly diff. not 100% sure if its a gtr/gts thing or just they changed the 32 headlights over the years though.
Edited by Inline 6
well i just found out i should be getting my car back in December or January its been such a long wait i cant wait to test the t04z etc out on the worked 25/30 at mallala should be fun.
R32 GT-R and GTST share the same headlights yeah?
I need a drivers side one - MINT.
God damn insurance dogs...
No. However some GTSt's do have GTR lights (such as mine, and Chads) The GTSt lights dont have plastic flaps with holes to hold the GTR grille in. So really if they have these, you should be fine..
And going on to what Dan mentioned, the "R32 S1" lights are slightly different in appearance to "R32 S2" ones. So just take note of how they look around the projector area.
whats she making Allan?
patience is a virtue! and ditto whats she making allan ? or not completely fin yet?
hey to all its been like 3 months since ive been on sau... or like 4-5 months since ive been to an event or cruise :P
car is on teh nom nom ... yeah it ate the crank key..... :) found out 3 months ago and havnt driven her since.. just sat inside her then and had a play with the pedals.... i miss being a couple inches off the ground and having extensive left foot exercise... worst thing is it makes sence that its been slowely dying for some time now.. and i think mallala was the final killer.. was never the same since then (6 months or so ago).
nearly finished paving the back carport so i can begin skinning my knuckles and getting to know my car even more.
by chance a few weeks ago mr lewis of lewis engines mt barker came into my work and purchased a very nice sandstone table off me and we got talking... looks like ill be having the privelage of a fully built rb26 when i can save enough coin.
on another note anyone after a pair of greddy t517z turbos with gasgets done 5000 kms approx for $2500
haha no worries mate.
yeah im planning on dropping the motor in on sunday, as Dale's bro in law needs the crane back, for
a long time by the sounds of it, poor bugger...
yeah if you cant grab them let me know, as ill be down south tomorrow and could possibly grab them??
i got an idea, how bout you bring them to me sunday and give me a hand?? :P
yer mitch, ill be there.
im gettin them tonite off the nug meister
as for you being down south, i'll be out near morgan most of the day haha, will arrange later on in the day to drop them to ya :).
sunday.......well if i wasnt workin on my shitboxes i would LOL
should be around the 380rwkw motor and manual box should be in 2way lsd is in nismo intake pump is in then theres the wiring of ecu etc so till it runs on the dyno im gonna say 370 to 380rwkw for now but i have to run her in yet so little hard to say.
So you were trying to sell me a munched out GTR for $28k?
should be around the 380rwkw motor and manual box is in 2way lsd is in nismo intake pump is in then theres the wiring of ecu etc so till it runs on the dyno im gonna say 370 to 380rwkw for now but i have to run her in yet so little hard to say.
probably using a 10 or 14psi spring in the wastegate so i can run it in abit and get the hang of the car again the way it reacts with these upgrades etc then boost it some more.! :P
Edited by R334door(s2)
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
