  • Replies 14.2k
thats f**ked reuben, sif people do that sorta shit
Tell me about it. The part was dumped in where the oil cap is ... and there is no way that part came from within the engine. The cap is lock-wired, as per usual scrutineering requirements, and the lock-wire had been removed. That made it all the more suss.
:P
Good thing tho the engine failed down the pit straight and not on any of the turns! f**ken dangerous prank! :D
:P
some people are f**ing retards.............
Well, got to see Twink at his finest last night! :P
HAHA you loved it.
You know you are doing badly when the only two girls that i was interested are a lesbian and one who has a fiancee.
HAHA you loved it.
really? when thats happened to me ive just seen a challenge.
Umm...Youtube Cara?
Usually something good there.
and yes Dave, im of the philosphy "just because there is a goalie, doesn't mean you cant score"
This cute girl who turned out to bat for the same team, yeah not much happened there.
This other girl was flirting a bit here n there..at one stage had her legs on my shoulders.. but yeah, found out earlier that she had a fiancee, but hey, she kept at it..what am i supposed to to about it i guess.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
