  • Replies 14.2k
WHAT??
if you find it is, let me know asap, i know where this mothr-fkr lives!
prick told me it was all sweet!
Kinda hard to tell if it is or not, but it doesn't look good. It's that or the harmonic balancer is bent or some shit. Either way it's not exactly 'all sweet' :P
It drives normal though, took it for a quick drive up the street before :D just makes a fkoff bad sound from the HB having it's way with the timing belt cover.
take the cover off, then skid.
then snap belts, then be up for more money to fix shit :D
Nah the cover actually looked loose at the bottom, like it was sitting closer to the HB. Probably why it's making such a fking racket.
There will be skids :P just wanna make sure I'm not gonna break it while doing them
my new ride
Miss Abby
Looks good Cara.
I think I've unofficially named my GTR 'F_ckin' Car' cause that's how I usually refer to it. Your names of Betsy & Miss Abby are much nicer.
Looks good Cara.
lol its Miss Betsy hahaha
and dont worry i think the 34 has been called every name underneath the sun lol
thank f**k i do teleconferrencing from my office
^^ the only teleconferencing you do is with 1800 numbers ya knob :)
Lol Krishy's phone time is more like:
"Hello may i speak to the business owner? Are you happy with your phone service?"
:D
well not the calls i have been answering all morning Damo....got damn i hate dumb users......specially when they feel its ok to do morning calls at 8am......what is this Krishy's hotline :@
