  • Replies 14.2k
WHAT??
if you find it is, let me know asap, i know where this mothr-fkr lives!
prick told me it was all sweet!
Kinda hard to tell if it is or not, but it doesn't look good. It's that or the harmonic balancer is bent or some shit. Either way it's not exactly 'all sweet' :P
It drives normal though, took it for a quick drive up the street before :D just makes a fkoff bad sound from the HB having it's way with the timing belt cover.
take the cover off, then skid.
then snap belts, then be up for more money to fix shit :D
Nah the cover actually looked loose at the bottom, like it was sitting closer to the HB. Probably why it's making such a fking racket.
There will be skids :P just wanna make sure I'm not gonna break it while doing them
my new ride
Miss Abby
Looks good Cara.
I think I've unofficially named my GTR 'F_ckin' Car' cause that's how I usually refer to it. Your names of Betsy & Miss Abby are much nicer.
Looks good Cara.
lol its Miss Betsy hahaha
and dont worry i think the 34 has been called every name underneath the sun lol
thank f**k i do teleconferrencing from my office
^^ the only teleconferencing you do is with 1800 numbers ya knob :)
Lol Krishy's phone time is more like:
"Hello may i speak to the business owner? Are you happy with your phone service?"
:D
well not the calls i have been answering all morning Damo....got damn i hate dumb users......specially when they feel its ok to do morning calls at 8am......what is this Krishy's hotline :@
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
