thing is basically i need someone to come to me, basically to find out what goes where and what im missing.
I have a 33 GTR you can have to compare if you want. I'm sick of it being at my house. You can have it for... ever.
  • Replies 14.2k
Cheers for the offers guys. What would help the most would be basically a engine on a stand with everything bolted to it lol
I've got heaps of pics and engine manuals which i might just try and work it out.
Still a atleast 2 weeks before it all gets serious.
Speaking of getting serious ... I've got all the bits I need for the swap now Luke. If next weekend is a bit tight due to your brother's birthday, we could prob still go ahead with the swap this weekend? I'll SMS you too about this. Let me know which weekend works best.
:worship:
as I sit here, oh so broken hearted,
I turned the key but the GTR just farted.
*sits and waits on driveway for RAA towtruck to turn up*
:ninja:
do you need someone to come on over (with consult laptop) and have a look with ya
use a 2nd eye/ear to diagnose
wanna sell ?
Most definitely.
1998 Black R33 GTR series 3.
~100k km,
400R Front Bar,
HKS 2530 turbos,
18" Nismo LMGT4 wheels,
Loud. Fast. Unbelievable!
PM me if you want to know more.
Most definitely.
~100k km,
400R Front Bar,
HKS 2530 turbos,
seen this car in person
its a primo example of a 33gtr. needs a bath tho
no lowballers on this one, its the shiznit
-D
probably too much for me then
Im seriously thinking about simply swapping the daewoo for a skyline, as i reckon it'd be easier to sell
well i doubt that, writeoff is kindly storing the vehicle for a friend
it all depends what the min sell price is, so I suggest u pm writeoff, u might score a bargain :)
-D
theres a 32 gtr for sale on ns.com for 12k ono
sounds ok but no pictures yet. not in sa though.
anyone no what the best brand and where the cheapest place is to get some front shock absorbers from???
wanna keep car stock height and i dont want coilvers
I have Bilstiens struts, and they are awesome! not sure where you would get them from, but a good place to start would be SA Suspension Centre or Car Toque on North terrace
better get out there today and sort the shit out in the 31.
whole rear seat area and boot in chockers with parts, just thrown in there :)
cant even remember what i have lol
then my missus work xmas do tonight, ahhhh more free piss, lovin it.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
