  • Replies 14.2k
This happened twice tonight, I'm going 55 in a 60 zone (to conserve fuel) and in both cases, a cop in front of me slows down to around 40, even when he has other cars behind him. Once he realised that my car is completely stock they turn off into some random side street, probably pissed off that he won't meet his quota tonight :wub:
i think you will find the police drive slow everywhere, unless there is a reason to be somewhere.
Thing is though, he was probably going 55-60 as well before he spotted me, and as soon as I slowed down to around 45, he slowed to around 40.
Meh, you want practical... buy a Hyundai Excel lol
cmon theres a difference between practical and pussy
like people running low low suspensions that cant even handle twisties because "oh it makes my wheels rub on the guards"
maybe think of running your car half a bees dick higher and it'll be able to >do what the car was designed to do<
autosalon spec suspension = fail. twisties + cruise/daily spec suspension = win. especially in south australia, where roads are designed by orks.
-D
-1
Impractical as buggery. Fine on jap roads but here you'll be rubbing more than oprah's thighs in a marathon
looks like turd to boot.
-D
Edit: +1 for Dohmars' second post.
discovered 3 things in the last 48hrs
1. Vics are very courteous drivers on their highways / freeways (ie if you're coming off an entry ramp, they change lanes so u can get in)
2. Amber lights dont stay amber long at all (barely a second)..........so no more "plenty of green in that" calls over there
3. i need an intercooler on the patrol BADLY
win, wonder if its static or bagged. extra points of its static dropped.
as for the practicality thing... meh, im running pretty low with a reasonably aggressive (*waits for jarrad*) wheel and tyre combo, and the only place ive ever had trouble with rubbing on the guards (im not counting liners, theyre retarded) has been turn 1 at mallala, over 100km/h and tipping into a long right without brakes puts a lot of weight into the front left corner, solution, bought it into the sheds, hammered the tabs on the guards down, went back out and it wasnt as much of a problem. skinnier tyre would fix it completely.
... could use some rca's though, then itd be spot on.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
