i leave those BIG O's in relation to dirt tracks to you and your mates :D
LOL well played good sir.
But i think you just didnt spell it right. Your quick wit has no cover for your blatant disregard for the english language.
  • Replies 14.2k
Indeed kind Jake.
However you have failed to obtain a Grammar Police Badge prior to this citizen’s arrest. You will find the following error in your message
Please in future run a spell checker to ensure your english authenticity before posting. Lest We Forget correct english in this fair country
Edited by Inline 6
lol just found 1 we both guilty of
Rule 13. Capitalize words derived from proper nouns.
Example: I must take English and math.
English is capitalized because it comes from the proper noun England, but math does not come from Mathland.
fck this english sht im going back to mathland where us accountants live in our dont give fek about english waste of time pay no bills krap
Edited by Inline 6
bye bye 17x7s, hello 17x9 and 9.5
Looks hot! but whats with the rear offset?????
What wheels where you running before? im in need of some 4 studs for the Ceffy.
*edited for the fags
Edited by DSTROY
Well spotted.
But you do know that it is an 'i'. Capital or not, it still represents the same meaning. Your failure to add another 'o' on the end of 'to', is quite a big mistake. There are three 'versions' of this.
'To', primarily indicates approach and arrival, motion made in the direction of a place or thing and attaining it, access; and also, motion or tendency without arrival; movement toward opposed to from.
'Too', means over, more than enough, noting excess, as a thing is too long, too short, or too wide,too high, too many, too much.
'Two', the sum of one and one, the number next greater than one, and next less than three, two units or objects.
they are the wrong way round chad :) i had to get new tyres but wanted to test fit lol, havent had chance to swap back yet.
the old rims sold, but they where too narrow for your use anyways mate.
they are the wrong way round chad :D i had to get new tyres but wanted to test fit lol, havent had chance to swap back yet.
I'm having trouble finding something in a decent size for a good price :) might go price up some drift teks for the front and run my little 15's on the rear.
My 18's wont fit cos they hit on the front struts, they might fit if i can get some coilovers though.
3 months? tried to meet a vilis nothing.. said deposit to my bank nothing.. now wont reply..
yeah probably say good bye to that money..........
to put it simply, hes a ex-boyfriend of a member on here... he attended a few events with her etc, when she dumped him he went all stalker like started rocking up at everything SAU he could and hanging out at BP every friday. eventually his true colours shone through (unfortunataly for dion) and now seems like hes doing it to adrian as well =\
spot on lukey
well i guess you missed out on him sitting on ur car then. least he picked my panels that wernt aluminum. as handsome as he is, only girls with DD"S are allowed to lean on my car and only if it involves me taking happy snaps or getting freaky.
good to know ill be able to lean on ur car dan......... hahahahahahaha :)
bbe, the point of that quote was what exactly?
shape up ya dunce
-D
calm down Ben
this is the same sort of post that you pulled Craig up on yesterday, i remember you nominating yourself for a possition in the last week which will call for restraint when posting from a position of authority :D
have a think :D
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
