  • Replies 14.2k
is there kits you can buy to replace all the hose's on a rb26. i thought i seen em somewhere but i can only see heater hose kits around.
i had a tiny leak in the radiator bypass hose but was thinking i might just replace them all for piece of mind.
apparently that 1 bit of hose costs $70.
Edited by Inline 6
Hey i went there and watched.. and it was hot as balls. I thought about putting my car down the strip but it was way too hot for it. so i just watched all action from the stands. there were a lot of nice cars out there.
thanks for coming and saying hi then :banana:
ok pop quiz, who can tell me what this hose is called or what it does exactly.
starts on left side of motor here, did lil angle. top of the pic you can see where it starts to say rb26 if you not sure where it is :P the hose im talking bout comes off near the large top radiator hose and heads to the right side of the motor
in which its hard to see exactly what its doing under nearth my turbo piping here. its the lower of the 2 skinny hoses here
just started leaking coolent on me, fortunately i only drove for about 2k when it happened and its a tiny pin hole so coolent was still full.
sale of wheels saga, entry number 46734:
found another dude whos keen, some random apprentice that owns a hr31 coupe, shall be collecting a deposit soon. rad.
any suggestions for new wheels?
viennas, hanging 12 miles out the guards
overfender the f**k outta it
then see if ya can get stickered before ya lose ya licence lol
*edit*
ive got nothing lol
Edited by Matty 31
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
