  • Replies 14.2k
is there kits you can buy to replace all the hose's on a rb26. i thought i seen em somewhere but i can only see heater hose kits around.
i had a tiny leak in the radiator bypass hose but was thinking i might just replace them all for piece of mind.
apparently that 1 bit of hose costs $70.
Edited by Inline 6
Hey i went there and watched.. and it was hot as balls. I thought about putting my car down the strip but it was way too hot for it. so i just watched all action from the stands. there were a lot of nice cars out there.
thanks for coming and saying hi then :banana:
ok pop quiz, who can tell me what this hose is called or what it does exactly.
starts on left side of motor here, did lil angle. top of the pic you can see where it starts to say rb26 if you not sure where it is :P the hose im talking bout comes off near the large top radiator hose and heads to the right side of the motor
in which its hard to see exactly what its doing under nearth my turbo piping here. its the lower of the 2 skinny hoses here
just started leaking coolent on me, fortunately i only drove for about 2k when it happened and its a tiny pin hole so coolent was still full.
sale of wheels saga, entry number 46734:
found another dude whos keen, some random apprentice that owns a hr31 coupe, shall be collecting a deposit soon. rad.
any suggestions for new wheels?
viennas, hanging 12 miles out the guards
overfender the f**k outta it
then see if ya can get stickered before ya lose ya licence lol
*edit*
ive got nothing lol
Edited by Matty 31
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
