  • Replies 14.2k
ive checked all 16 pages of the diy thread..... how do i remove all the hicas pumps in engine bay correctly and how do i remove the abs?? anyone now of a step by step information page?
Jenkies u will need a non abs brake master cylinder and possibly some new lines made.
And Jake I'm not a mechanic I just know some car info lol
aww man thanks... nothing is ever perfectly easy is it :)
see my gtr for an example :) i dont regret not having abs, it hardly ever locks and when it does its pretty easy to ease off and get it gripping.
mine is the opposite.. i find it pritty easy to lock all 4s up with ABS, but that might have something to do with tyres XD
you bloody legend! ive never ever had the abs actually work on me which means my pedal control must be decent.. need the space to mount a catch can so i can leave battery in bonnet! thanks again chad
Anyone know how to replace wheel bearings? or a link to how to do it...
you'll need a press as they are pressed into the hubs, And if they are anything like the S-Series they are like $90 each for the bearings.
He can just split the front and rear lines and then put a biasing valve on the rear line. regency will be happier with a factory non abs setup though. although he'll have bigger problems if regency ever look at the car.
Edited by D_Stirls
what tyres you got? i got cheapish tyres (nankangs) but mine are 275s all round so that probably helps me a fair bit.
and also post-31501-1263854503_thumb.jpg 4466
Edited by Inline 6
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
