  • Replies 14.2k
ive checked all 16 pages of the diy thread..... how do i remove all the hicas pumps in engine bay correctly and how do i remove the abs?? anyone now of a step by step information page?
Jenkies u will need a non abs brake master cylinder and possibly some new lines made.
And Jake I'm not a mechanic I just know some car info lol
aww man thanks... nothing is ever perfectly easy is it :)
see my gtr for an example :) i dont regret not having abs, it hardly ever locks and when it does its pretty easy to ease off and get it gripping.
mine is the opposite.. i find it pritty easy to lock all 4s up with ABS, but that might have something to do with tyres XD
you bloody legend! ive never ever had the abs actually work on me which means my pedal control must be decent.. need the space to mount a catch can so i can leave battery in bonnet! thanks again chad
Anyone know how to replace wheel bearings? or a link to how to do it...
you'll need a press as they are pressed into the hubs, And if they are anything like the S-Series they are like $90 each for the bearings.
He can just split the front and rear lines and then put a biasing valve on the rear line. regency will be happier with a factory non abs setup though. although he'll have bigger problems if regency ever look at the car.
Edited by D_Stirls
what tyres you got? i got cheapish tyres (nankangs) but mine are 275s all round so that probably helps me a fair bit.
and also post-31501-1263854503_thumb.jpg 4466
Edited by Inline 6
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
