  • Replies 14.2k
Depends what you want i guess, Internally gated or External.
GT3071R Dual BB rated at 500hp, $1,815
GT3071R T25/T28 Internally gated with a .64 rear housing, $1,795
GT3071R T25/T28 internally gated with a .86 rear housing is also the same price as the one above.
Courtesy of Tweakit.com.au
its pretty expensive build to do tho.. some1 told me on ns.com to have 20g ready to do the 3071R turbz on my pulsar(plus the supporting engine/diff upgrade) he also told me my straight cut gears wouldnt be able to handle 300awkillerwasps, is there many things stronger than ppg straight cut gears?... bit of a turn off right there...
Jeremy i reckon he doesn't know what he's talking about 20k is rather large and gtir are already turbo
only thing is 3071r on a 2.0lt might be a bit laggy
ring AM Performance he makes dumps and might know a lot more about the gtir that some rando on NS
oh and i know 3071r isnt rated for 300kw i just asked about that seperately.. if it was 15k id do the pulsar, 20k is pushing it... got to get rid of the stupid s13 :)
How much for the sil?
lol that turbo will do all of that.....should be quite responsive with a small 0.64 rear housing.....mine is a 0.62 or a 0.63 rear housing and see full boost by 3200-3400rpm.....
http://www.lovecricket.com.au/
so far my highest score is 105
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
