  • Replies 14.2k
:D
depends how soon you want it towed south Abe i might be able to help out
krishy, PM coming your way mate. i got BOTH of ya messages LOL
When are you able to do it, trying to organize fitting with Luke, so it may have to stay awhile at Dion's, or at Luke's. Shall let you know, trying to find a clutch and price first.
It doesnt matter here at all, even if we get the mustang back while its here we can still fit that in there too.
Its just a case of how long you can bare to drive my daily :D
lol, that thread on NS is good value
think knowing that its been uncovered that the user UUP4IT has many users using his account, and he's selling stuff for his mates, is it worth doing anything with him here (i think most people could put 2 and 2 together and work out who he is :D)
lol, the way he writes/his posts gave it away.
to that user: if you read this, just stop posting... you're making yourself more and more of an accessory ya goose.
Update guys.
From painting the engine bay and hoping to have it ready for all jap day, that idea has been scrapped. Engine bay basically got painted then thought Fu*k it, lets take my time not rush it and do something crazzzzzzy.
Engine bay is slowly getting worked on after work, roughly 4-5hrs each night. The front wheel arches have been cut out and getting tubbed :D, im currently grinding back all the seams to be seam welded, takes roughly 10hrs each side to grind out, not including underneath the car yet.
Dropped the fuel tank out tonight and have decided i will be cutting out the spare tyre well and running a fuel cell/drop tank with braided lines ready for e85.
Fuse box/battery will be relocated to the boot.
No pics yet but will be one night soon.
Cheers
Wont be going peddle box Matty, to much effort modifying the seat/gb leaver to fit it in.
Also will be having bracing through out the engine bay and underneath to help the chassis strength.
All fun tho, come out covered in black shit and seam sealer.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
