  • Replies 14.2k
well i just had the worst most blood curdling experience siting down stairs waiting for the folks to get home when i hear the car pull up and wait for a ding dong
when i hear a child scream i thought nothing of it because we have kids over the back who throw tanties from time to time when the amplitude of the screaming doubled and i went to the back door to only realise it was my daughter screaming
when i got to the front door she was running to it screaming daddy daddy holding her fingers i rushed her in to see no blood phew no blood so i took her in praying for little fingies and running the the paracetamol you can never be to care full with kids and electric windows, i also think nan and pop panicked when they heard the screaming and rather than open the sun roof they closed it further, but the toyota camry has a stupid switch mechanism
all is well and daughter is in bed with ice pack in tea towel on fingers
oh sh*t have you gone and checked her fingers again
whoa. http://www.skylinesaustralia.com/forums/Hk...-T-t307108.html
My dad has one Ruby, but its *just* too small for IC piping, so youd have to file away at the tray to make it bigger.
I might have to get my own. BTW trying to find a pic or link of the position others have used for the fmic piping hole under the battery tray. I'm having no luck. Anyone got a pic or link?
When Jenkies and Chad did mine, it was basically a ready, aim, fire type cut :P
When Jenkies and Chad did mine, it was basically a ready, aim, fire type cut :)
I found a pic of where the hole was cut in an R34, so I'll take a punt from that. Off to Bunnings at lunchtime today I guess. :P
pretty much. theres a bit of praying involved, had to extend mine about 3/4 inch because i missed the mark a little... :)
found a pfc... to buy or not to buy...
hahah arent you selling the tractor soon dave???
oh my
quality - purchased an R32 GTR GTS alloy 52mm dual-core race radiator off ebay
$199 delivered, WOW amazing quality work. australian made.
also received 6x 550cc siemens injecotrs ($360 delivered - new), and a $30 5-point race harness
plus a $160 305Liter/per/hour external walbro pump.
awaiting surge tank & 5m braided fuel line now
also waiting on a $15 remap chip
almost got everything for the track car now. awesome
fuel pump: http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWNX:IT
radiator: http://cgi.ebay.com.au/52mm-Alloy-aluminum...=item414cfdbe40
injectors: http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEWNX%3AIT
oh my
So would you recommend the radiator? As i am looking at getting a replacement for the stock radiator before the SAUSA track day.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
