  • Replies 14.2k
that reminds me, I'm spewing that I didn't head over to Melbourne for the UFC last weekend.........reckon Carl would be too. :P
You would've had the same view as you had here - on TV. It was held in Sydney :(
Some cocksucker put plastic stuff all over my R32 while it was parked, and it had something on it that I can see on the paint. It better wash off
piece of shit low life people
where did that happen mate?
done deal!!
that reminds me, I'm spewing that I didn't head over to Melbourne for the UFC last weekend.........reckon Carl would be too. :ninja:
That was live on One HD on sunday last week wasnt it???? some awesome fights and KO and submissions
yeah sorry Dave....I've got Melbourne on the brain cause I need to get over there for a day or two.
Rad32 and I just got back from Melbourne and it from news reports it was pretty much UFC in the CBD with 17 people stabbed in two nights or something. Great city to be in haha
Everlast Auto Group on Pt Wakefield Rd
I almost had a heart attack when i seen that. A sister company to who i work for is called "Everlasting Watertanks", made me think they were almost related.
lol u take that pic damo? we got to go out on our boat to go and see it today. seen dolphins on the way to :ninja: awesome start to the day.
o and it is bigger than the titanic was
titanic
Class and type: Olympic-class ocean liner
Tonnage: 46,328 gross register tons (GRT)
Displacement: 52,310 tons
Length: 882 ft 9 in (269.1 m)[3]
Beam: 92 ft 0 in (28.0 m)[3]
Height: 175 ft (53.3 m) (Keel to top of funnels)
Draught: 34 ft 7 in (10.5 m)
Depth: 64 ft 6 in (19.7 m)[3]
Decks: 9 (Lettered A through G)
queen victoria
Tonnage: 90,000 gross tons
Length: 964.5 ft (294 m)
Beam: 106 ft (32.3 m) waterline, 120 ft (36.6 m) extreme (bridge wings)
Height: 205 ft (62.5 m) keel to funnel
Draft: 26.2 ft (8.0 m)
Decks: 16 total, 12 passenger
Installed power: 63.4 MW Sulzer ZA40 diesel plant
Propulsion: Two 16.7 MW Azipods
Speed: 23.7 kn (43.9 km/h; 27.3 mph) maximum,
service at 18 kn (33.3 km/h; 20.7 mph)[2]
Capacity: 2,014 passengers
Crew: 900 officers and crew
but not as big as the RMS Queen Mary 2
Edited by Inline 6
thats nothing out of the ordinary for melb.....they had a doco on the tele a couple of nights ago where the "gangs" were speaking to the journalist in regards to what they do and they covred their faces like the terrorist's do in afghanistan.....pretty bad over there.....one of the guys said that they just go into town and start fights etc for no apparent reason.....i mean wtf is going on over there
oh and damo what ever floats your boat mate
I can just appreciate the design and engineering that goes into something this big. I f**king love watching Nat Geo and Discovery for stuff like that, watched them build one of the worlds biggest oil tankers, and how to build an off-shore oil rig. Fascinating shit.
If you sold your car Krishy, youd get 3-4 nights in the Queens Grill Room. Just over $4000 a night.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
