  • Replies 14.2k
anyone know?
also dale if you read this or anyone else,
i wanna put my afm between plenum and cooler, coz my intake pipe is too big to fit it, will this be better as it wont have air recirculating?
grab a Q45 afm, larger diameter, i think?? 90mm from memory
you cant do that as the air in that section is compressed by the turbo, which means its temperature is different from ambient, and it cant calculate the volume properly. afm's must be before the turbo.
-D
Wrong, it can be done. As Craig said, proof is in Simon's drift car. Andrew made an awesome clamp setup so it wouldn't burst under pressure and the car takes a beating. Not a problem in the world
-D
as luke said. wrong. been covered numerous times. the afm cares not for pressure or temperature of the air passing through it, and any air passing through it will be the exact same volume after the turbo as it would be before the turbo.
Edited by scandyflick
On my RB30ET inside my VLCT - I had the AFM positioned on the 'cool' side of the intercooler and never had problems with it ever. If you can, use the T-bolt style hose clamps either side of the AFM to ensure that you wont blow intercooler pipes off.
Will be fine Age.
Edited by Weezy
I stand corrected... MAP sensors work in the same position ?
-D
anyone know?
You will need a remap went you do it, it will run without the remap but to make the most from it you will need a tune.
The thing that i question with the cool side AFM mods it the integrity of the AFM casing itself, with the AFM i have i can push in the square section above the circuit board with my finger so i don't know how 20+ psi of boost will go with it. (some quick maths, that plastic section is 4"square inches. So that is 80 pounds (36.67 kg's)of force on a thin piece of plastic.
Edited by D_Stirls
i guess thats how its constructed, I've seen a few companies that have removed the nismo AFM electronic components and welded them into steel pipes of the same diameter... not sure if thats why they did it..
Im guessing the retune is needed due to the temperature of the compressed air?
scandy - with the air on the intake side of the turbo, are we sure its the same volume? - it will be sucking in a lot of uncompressed air before the turbo compresses it, hence making the air more dense and increasing the temperature to boot - makes me wonder just how those AFM's work with their 'flow' under vacuum and flow under pressure - I know they have a 0-5v feedback depending on the calibration of the unit, but the science of it eludes me at this time
kellie, pretty sure gaugeworks dont do defi, they do spitfire and vdo and a bunch of others (mostly mechanical gauges as opposed to the defi's being electrical)... that said the VDO's are great
-D
has anyone used or heard of ASHLEY HOBSON from classic performance dyno centre in hackam???
Good bad?
Yep I take my 32 GTR there after Boostworx moved out North.
He's got an awesome dyno cell setup there, and really knows his stuff. He's real friendly, and when I took my car there, he took me for a tour of the workshop, put the GTR on a hoist, pointed out a few things, explained heaps... really helpful. First place to ever really do that for me!
Dyno'd my car and told me a heap of stuff with it, awesome print out and stuff. He used to work for Graeme West for years and then decided to open up his own place. He deals with old school muscle cars and Jap imports... they used to have a 300+kw 33 down there that he built up, too.
I highly recommend them :P
Reminds me I have to book my car in down there again soon!
Are you sure you are not confusing volume and mass???
By definition, doesn’t compressing ambient air change its volume?
I know the AFM in the cooler piping works but I am yet to fully understand how it could provide the right reading to the ECU
I agree I am confused too, as surely when the temperature of the compressed intake air varies so wildly (even once intercooled) the ECU cannot adjust effectively enough to not pop the engine.
Ok here goes;
The Nissan style MAF/ AFM (hot wire) works by a wire being cooled by flowing air, which i'm sure most of you know. Now what cools the wire is the actual atoms that make up "air", now as the temp of the air increases the density of the air decreases which means that then there are less atoms per volume and the cooling affect of the air is therefore less per volume.
This also means that there is less oxygen per volume which is why we run intercoolers to try and regain some extra density from the intake charge before it enters the plenum/combustion chamber.
So this mean that a MAF is less sensitive to temp changes that other forms of systems because what it is actually measuring changes as the temps are increased.
Now the reason that i said that the after turbo AFM mod's needs to be tuned is more to do with the VQ table that the ECU uses than temp correction. This table says that for a set voltage there is a set mass air flow. This air flow is calibrated to the size of the AFM body amongst other things, so if you change the body size you change the amount of air that passes for the voltage put out.
These calibrations (and the tune in your ECU) are worked out with the AFM being in a vacuum and the air being drawn through the AFM, once you put it on the pressure side for the set voltage you will be getting more airflow as it's now a pressurised system and the flow is therefore increased.
The AFM being out of calibration doesn't really matter though as you can tune around it, it just means that you can't just swap it to the other side and drive away. It would drive fine once the mod has been done while you are driving around under vacuum, as it is the same as it being before the turbo in terms of calibration but once it hits boost it'll stuff up your mixtures.
When i say you can tune around it is because the ECU doesn't care about air, infact it doesn't even know what air is. The ECU takes the voltage reading from the AFM and says well i have this voltage so i need this amount of fuel (using the fuel tables set in the ECU). When you tune an ECU you are adjusting the amount of fuel for the amount of voltage the ECU is seeing from the AFM. You adjust it using a wideband O2 sensor as reference and you are adjusting it to achieve the desired Air Fuel Ratio that you want to run.
This is a simplistic view of tuning and what is going on, but you should get what i mean.
Edited by D_Stirls
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
