  • Replies 14.2k
Cara I really disagree with your thinking here. I know you feel guilty but hiding from it is not going to solve it. Go and visit your friend. Tell him you are sorry. He will forgive you. He was there and he knows how quickly it all happened. You both need to talk about it and as Krishy said you both will feel better afterwards. The reason that he was in the car is because he was your friend. Be his friend now and go and see him. It won't be as difficult as you have built it up in your mind.
He will need you help and support for rehab. You will need his help and support to deal with your guilt. Don't abandon each other now when you need each other the most. That is the true test of friendship.
i had an appointment with my pschologist today to talk to him about what happened on saturday...he said what im feeling/thinking is perfectly normal and that i should go see Charlie when i am ready....and not to force myself to go. I have sms'd him to make sure he is alright but that is as far as i can do at the moment i am still having trouble with realising that it all happened on saturday, im having nightmare after nightmare aswell which isnt helping.
Is it possible your feeling guilty because your weren't paying attention and singing songs driving and being silly with your mate when this unfortunate accident happened
“Do not judge, or you too will be judged. For in the same way you judge others, you will be judged and with the measure you use, it will be measured to you (Matthew 7:12).”
you were stupid enough to assume that i was f**** around in the car and not paying attention to the road
and the way u said it was not asking a question, but was assuming that is what i was doing.
anyway im not wasting anymore energy on this, or you for that matter.
possible
Main Entry: pos·si·ble
Pronunciation: \ˈpä-sə-bəl\
Function: adjective
Etymology: Middle English, from Anglo-French, from Latin possibilis, from posse to be able, from potis, pote able + esse to be — more at potent, is
Date: 14th century
1 a : being within the limits of ability, capacity, or realization <a possible but difficult task> b : being what may be conceived, be done, or occur according to nature, custom, or manners <the best possible care> <the worst possible circumstance>
2 a : being something that may or may not occur <a possible surprise visit> b : being something that may or may not be true or actual <possible explanation>
3 : having an indicated potential <a possible housing site>
need i hold your hand further through the english language like half of SAU that doesnt read or comprehend /caring
The way you phrased your dialogue only questions the possibility of her guilt. It is continued with a statement 'because you xxx' which implies fact when not concluded with a question mark.
English grammar fail.
-D
i wouldn't conclude that sentence with a question mark as its not a 'why' 'who' 'what' yadda yadda
You started the dialogue with an open question, that being the word "Is" which implies a question, and hence would end the sentence with a question mark unless a preposition or caveat is mentioned, which you clearly did.
keep miss reading i don't care
Grammar fail #2
-D
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
