i need the intercooler hose than joins the "twin turbo" pipe to the intercooler piping in the passenger-side skirt.
from factory it has a foam cover on it, because it sits under the airbox snorkle.
give koji a call at Japanese Import Spares, I dare say he'd have something
-D
  • Replies 14.2k
he messed me around yesterday, wasting 20 minutes of my time to tell me he can't sell it to me because its on a half cut.
I called him the other day for a standard airbox, said he has one, came in today to buy it but he couldnt find it! Wasted my time going up there for nothing.
nexcess' facility doesnt look that great :S
what do u mean? looks fine to me. underfloor wiring, diesel backup generator, ups transitional supplies, oodles of bandwidth
seen a few data centres in my time, they all look just like that....
-D
Edit - apart from the fact its located in michigan? huh? I thought the servers were coming back to aus (unless the transition hasnt happened yet?)
check this out for one of the most retarded reporting ever
http://www.dailytelegraph.com.au/ipromise/...h-1225842561655
dude has an ae86, not a celica...
not to mention somehow they believe pod filters can get filled with petrol and then explode...
the comments are truly disturbing
-D
-D
Eh, been in lots of datacenters in my time - in Brisbane, Sydney, Melbourne, & Adelaide. I guess comparitively to the *good* ones I've been in, it didnt seem that great - up to par with a *reasonable* level one, but just nothing 'special'. I was also a bit surprised they didn't really give much details on their network capacity on their site.
Forum is heaps faster. <3 it.
-D
Yep Christian posted a message this arvo and the migration hasn't actually happened yet .... outage was just preliminary backup works or something to that effect.
coolness
that reboot made a huge difference tho lols
anyhow, if the migration is yet to happen, im lookin forward to it
-D
LOL watched MXC before on Fox 8 - haven't laughed so hard in ages. The cheesy American voice-overs are absolutely classic. If you haven't seen it before do yourself a favour and watch/record it on Fox, or acquire it from other source. Definitely worth it!
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
