  • Replies 14.2k
Phew - washing, chamoising, scratch repairing/cutting, polishing, waxing then trim detailing your car is absolutely exhausting in this (even mild) heat. Going to wait until it is a bit cooler to do the inside cleaning/vacuuming then she is ready for a final exterior wet coat Saturday 6am.
Mind you, the 35 is now looking a million bucks :D
I'm gona spend all Friday night giving my car some lurve getting it ready for saturday.
in fact what polish/scratch treatment do you use for the black duco Andrew? Is it a light compound treatment? I don't want anything 'too' heavy duty that is going to removed a few layers lol
Edited by Weezy
f**k that
i intend on fighting these cockmongers
no retreat, no surrender
-D
Dunno if you saw the news tonight but Rannwit has made a backflip and is now willing to talk about this motorsport complex, he just doesn't want it at Gilman he wants it somewhere else
Is that right hand side standing at front of car or right hand side of radiator?
So they bolt into R31 as well??
I need bigger radiator, now with the FMIC installed the water temps have gone from under the 1/4 mark on the gauge to over half way...
lhs standing from front of car (drivers side) /rhs looking at it from the rear of the radiator
snap, beaten to it. sorry bout that shane, shoulda clarified it. I know you can do a 33 rad into a 31, just modifying the way the top mounts are (33 are horizontal, 31 are vertical, literally bend them 90 degrees and snap it fits)
on another small note, i can go buy my winch tomorrow w00t
who can say no more push recoveries for non-running cars?
Yeah ... prob Murray Bridge!
At this point in time, I don't care. I'll travel to Murray Bridge if I have to for a decent motorsport venue. As long as they can cater for competitors, spectators, volunteers and all vehicles with all the proper infrastructure and services, then I'd travel to use it than a run down, derelict venue.
I can imagine many people will complain if its a fair trek to get to it ... but most of them wouldn't use it anyway. They'll find other excuses to hoon about on the public roads. You could stick the venue right in their neighbourhood, and they still won't use it.
If its modern and has decent infrastructure, the serious people will travel for it. Hell, I'm bored with Mallala right about now. My next track day is at Eastern Creek, then Phillip Island not long after. I'll gladly travel for a decent venue.
A mate of mine whose just come back from darwin, says the track days they have up there..kinda like our saturday night drift pracs, cost something like $70, and you go for a blat all day.
If they can do something like this..then yeah, im down...lend me a car someone? :P
damn took so much time in cleaning the wheels but they look at least respectable now.....car is cleaned and looks decent enough for the show.....thanks once again for Matty the towbitch for towing my car again.....cant wait to get back and enjoy a beer with ya mate
now i am so f**king exhausted....time to go and watch some ufc later on
okay........ i've been f**k assing around all week organising tyres on the ninja for the meisters. I assumed 245/40 stretched on a 10" wide rim would be suitable enough to be able to get my car in and out of my driveway without the front guards bring rolled, but NO! Fail... Can't get back up my driveway. 1. I wna slap the cvnt that designed our house 2. I wna slap my car for giving me the sh!ts and no 3. lol
Okay, so now I need to get my front guards rolled, I'll get onto wheelworx about that later unfortunatly its going to be boring-spec stockies for the car show this saturday :( I don't even wna enter now thats how over it I am.
end. f**king. rant. ffs. aids.
Cheers anyway man.
Now I have to wait untill the guard gets changed because when the lady reversed into me, the guard was replaced and the indicator hole wasn't lined up properly *not on the painters side* but they didn't check to see if holes were the same they had just assumed they were being a compliance thing, as you would I spose? And now they're going to replace it again and get the indicator holes parrlelle each side to each other so I have to wait for that :( FML
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
