i have no words to describe the stuff found in this thread...
http://forums.overclockers.com.au/showthread.php?t=860659
im not sure if i should laugh at the stupidity, or be appalled at the sheer amount of bigots....
the whole site is unbelievable
  • Replies 14.2k
Hey Chad,
what offsets are you running on your Stagea, and what size tyres. I'm putting on GTSt brakes and need some spacers so I may as well fill the guards out while i'm at it.
The rims I have at the moment are bogan/bob-jane spec +38 18x235s I'm thinking 25-30mm spacers front, maybe 15mm rear or just leave it as they are.
19x8 +30 on the front with 30mm spacers with 235 tyre and they rub on the guards so could do with a 25mm spacer instead. Rear are 19x9 +30 with 235's and they fit sweet.
what are your thoughts on these:
330mm with brackets,
Slotted & Ventilated
Dynamic Balanced
Heat Treated *Surface Coated
Heat resistance up to 900 degree.
$595 on trademe.
or here: http://www.conceptzperformance.com/Cart/de...29118.210.8.101
326mm with brackets, $430usd + postage
also arranging:
hks 87mm pistons & attkd h-beam conrods
acl race main & conrod bearings
ati 600hp harmonic balancer
rb26 clear cam timing cover
apexi multichecker
hks step-2 valve springs
hks oil pump
$3000 delivered. woot. double woot
I have been reading some of the Landover Baptist stuff Carl .... freaking hilarious ;) .... some of the appalled reactions to what is clearly a joke site are off the dial hilarious. Love this one in particular:
http://www.landoverbaptist.net/showthread.php?t=27676
try not to get cross drilled rotors Brendan they're more likely to crack
My GT-R rotors have tiny little hairline cracks 1 - 2mm long coming from the cross drilled holes,
very shortly I'll be looking for some slotted rotors, along with a brakefluid flush
Edited by Weezy
What happened to race car on a budget brandan? I mean its good if you can get these parts cheap but the costs are going to take you on a roller coaster and before you know it you've spent way more then you had intended lol
it has to be the biggest troll in the history of the internet. the size of the forum is amazing hey
yeh this is for down the track - auto awd rb26 stagea ;)
the sale of parts from the r32 sedan and my current engine will suffice
ie: rb25 ported head, tomei camshafts & valve springs - $2000
rb25 gt3076 garret ball bearing turbo - $1500
rb25 bottom complete bottom end with rwd gtr sump - $500,
rb30 manual box, tein r32 suspension, injectors, splitfires, - $2000
gtr fuel pump, stagea brakes, gtr front calipers, Panoz racing 4-pot billet calipers - $1000
gtst sedan shell, other bits etc, a few more grand easy.
fkn Chinese shit!
took the gate off this arvo, yep, was stuck open, taped it with a hammer, put it back together and back on,
started it up and woooot, i had boost again! gave it a good hard rev after it warmed up, and bah! prick of a thing stayed open.
ahh well, def in the market for a new gate soonish.
<3 the flutterz thru stainless intake pipe tho ;)
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
